    I think I killed my Gray
    M5stack Grey
    gray adc
    6.8k
    • D
      dclaar
      I hooked up a 10K resistor and a CDS cell (resistance 50k-1M) in series from 3v3 to GPIO36. I set the pin to ADC mode, and was reading between 3000 & 4095.
      But now the gray isn't working. It doesn't show up as a serial port on the PC. If I try playing the built-in rock/paper/scissors, it goes black as soon as I push a button (https://claar.org/gray.mp4).
      So, did I kill my gray? If so, what did I do wrong? I don't want to repeat with another piece of hardware!
      Google suggests that 10K should be plenty as a pullup, and an ohm meter shows that the resistance goes between ~60K to 1+M, so I didn't use the wrong resistor (and the CDS is 50K in any case).
      • D
        dclaar
        This was the super-frustrating "windows doesn't recognize a device. But a different windows computer does". :(
        • m5stackM
          try to upload the latest version firmware by M5Burner.
          tutorial link.
          https://docs.m5stack.com/#/en/quick_start/m5core/m5stack_core_get_started_MicroPython
          • D
            dclaar
            Thanks, once I got the other computer to see the device (can't flash a device that doesn't show up in device manager), I was able to reflash it.
            Then I took it back to my laptop, and it still wasn't seeing it. So I switched USB cables, and it did. Then I switched back to the original USB cable, and it worked with that cable again. (Note that I had hooked up a M5StickC via the original USB cable, and it is working fine with that cable now, so the cable isn't bad).
            Gotta love Microsoft Windows sometimes.
