@ajb2k3 When might we expect version 2.0?
Best posts made by Conrad
Latest posts made by Conrad
    RE: M5atom Matrix library (micropython)posted in PROJECTSI would like to try the examples, but I don't know how to external use/import the modules/libraries like matrix.py. I've looked in most places but I can't find anything documented anywhere. I'm using UI Flow desktop v1.4.5. If you could point me in the direction of how I can use external modules/libraries with UI Flow desktop or what other IDE would be better I would much appreciate it, thanks.
    RE: ATOM Matrix - basic working Access Point (micropython)posted in Cores@m5stack UiFlow Version 1.4.5 (Desktop) Issues - Pressing </> Python:
 At any time wipes out any code you have in the edit window, why? - Cannot save code, also two methods available to save:
 Or
  Using either method saves a main.m5f file (Note, not a main.py), opening the main.m5f results in: rom m5stack import * from m5ui import * from uiflow import * rgb.set_screen([0,0,0,0,0xFFFFFF,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]) setScreenColor(0x222222)Ok, so I thought I would change version via the Ver button at the top of the screen, now all I get is:  - On startup I get:
  Everytime even though the driver is installed. I select Skip which takes me to the main GUI which informs me the Atom-matrix is detected. - Basic editing navigation via shortcut keys such as <ctrl> S don't work - very annoying.
 Because of the Javascript error I can't open in UIFlow anymore to continue.... Now I'm stuck. Please tell me I'm doing something wrong and being a complete idiot...
    RE: M5atom Matrix library (micropython)posted in PROJECTS@robalstona Thanks for posting, I might give this a try!
    ATOM Matrix - basic working Access Point (micropython)posted in CoresThought people might be interested in a simple working example of an Access Point web server on the ATOM Matrix:
 (Wasn't sure if this was the correct place to post ...)Based on:
 https://randomnerdtutorials.com/esp32-esp8266-micropython-web-server/
 http://community.m5stack.com/topic/1262/m5stack-basic-grey-as-wifi-apKnown Issues/Bugs:
 Very flaky - crashes lots .. Seeing micropython REPL error:
 File "<string>", line 77, in <module>
 OSError: [Errno 104] ECONNRESET
 Atom dies.... Needs hard reset.Not sure why only momentary display Green/Red, looks like constant socket accepts..
 Need to investigate the unused addr return from socket accept, is this useful?
 Response Initial state affected by loaded page in browser?Anyway, all constructive comments welcome. One for m5stack: UIFlow-Desktop V1.4.5 is awful, can't even save my micropython code, please, please fix/update. How do I get the listing to display as code like in other posts? DONE - see below! from m5stack import * from m5ui import * from uiflow import * import network try: import usocket as socket except: import socket request_state="NULL" waitingConnect = [0xff0000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0] acceptedConnect = [0x00ff00,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0] def web_page(): html = """<html> <head> <title>Conrad's Web Server</title> <meta name="viewport" content="width=device-width, initial-scale=1"> <link rel="icon" href="data:,"> <style> html{font-family: Helvetica; display:inline-block; margin: 0px auto; text-align: center;} h1{color: #0F3376; padding: 2vh;} p{font-size: 1.5rem;} .button{background-color: #00aa00; display: inline-block; border: none; border-radius: 4px; color: white; padding: 16px 40px; text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;} .button2{background-color: #aa0000;} </style> </head> <body> <h1>Atom-Matrix Web Server</h1> <p>Response: <strong>""" + request_state + """</strong></p> <p><a href="/?led=on"><button class="button">GREEN</button></a></p> <p><a href="/?led=off"><button class="button button2">RED</button></a></p> </body> </html>""" return html ap = network.WLAN(network.AP_IF) ap.active(True) ap.config(essid='Atom-Matrix') ap.config(authmode=3, password='123456789') response = None s = socket.socket(socket.AF_INET, socket.SOCK_STREAM) s.bind(('192.168.4.1',80)) s.listen(5) while True: rgb.set_screen(waitingConnect) conn, addr = s.accept() rgb.set_screen(acceptedConnect) request = conn.recv(1024) request = str(request) led_on = request.find('/?led=on') led_off = request.find('/?led=off') if led_on == 6 : print('LED ON') request_state="ON" rgb.setColorAll(0x00ff00) elif led_off == 6 : print('LED OFF') request_state="OFF" rgb.setColorAll(0xff0000) else : request_state="NULL" response = web_page() conn.send('HTTP/1.1 200 OK\n') conn.send('Content-Type: text/html\n') conn.send('Connection: close\n\n') conn.sendall(response) conn.close()
