We 3D printed a sleeve that makes the M5 both wearable as a lanyard and allows the power button to be easily pressed.
Our customers use the M5 to send a MQTT command that briefly changes the content on a TV from cable/satellite programing to their own internal marketing images and videos.
Our issue was that running the command and then putting the device in deep sleep with the A button had a battery of just a few hours.
Using the power button worked but it is hard to push especially when worn around the neck.
This sleeve has solved the "mechanical" issue with trying to actually use the power button.
We are getting several days of battery life which is more than perfect.
Paul Wheeler
Local Business Patriots
