    2. maechler
    • Continue chat with maechler
    • Start new chat with maechler
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Save
    Saving
    maechler
    @maechler
    Reputation
    9
    1199
    Profile views
    0
    Followers
    0
    Following
    Joined Last Online
    maechler Follow
    Posts made by maechler
    • RE: Connect units to PbHUB
      I ended up copy pasting the method from the Light unit with some slight adjustments:
      def pbhubAnalogRead(pbhub, pbhub_address):
              data = 0
              max_val = 30
              min_val = 750
              for i in range(0, 10):
                  newdata = 750 - pbhub.analogRead(pbhub_address)
                  data += newdata
                  if newdata > max_val:
                      max_val = newdata
                  if newdata < min_val:
                      min_val = newdata
              data -= (max_val + min_val)
              data >>= 3
              return round(max(1024 * data / 750, 0), 2)
      pbhub = unit.get(unit.PBHUB, unit.PORTA)
      light = pbhubAnalogRead(pbhub, 0x01)
      The magic number min_val I got by pressing my finger on the light sensor (blocking all the light from entering) and reading the analog value. The value 750 seems to be the minimum value the light sensor would emit. The number max_val I got by pointing a strong light at the sensor, it seems to be the maximum value the sensor emits. The min max values are mixed up because it measures the resistance and decreasing resistance means increasing light intensity. Using this method I get values that are somewhat similar to what I get by connecting the Light unit to PortB directly.
      If anyone knows how this should be done properly, please let me know!
      posted in Units
      maechler
    • RE: How can I start my micro python program at reset
      I placed my stuff into the /apps folder, e.g. /apps/demo.py. On startup you can then press the button in the middle to enter the app list, choose your app demo and from there on it will be started automatically when you reboot.
      posted in Micropython
      maechler
      @ws1088 Thanks for the clarification!
      Do you say that the value I get with pbhub.analogRead(0x00) should be plugged in for newdata in Light.analogValue?
      I would have placed it where the Light unit calls self.adc.readraw().
      Do I also have to call pbhub.analogRead(0x00) 10 times in a loop, as the Light unit does?
      @ajb2k3 Yes, kind of. I have tested what the Light unit does for increasing values of self.adc.readraw() it will output decreasing values. This inversion is missing when reading directly from PbHUB.
      class Light:
          @staticmethod
          def analogValue(value):
              data = 0
              max = 0
              min = 4096
                  newdata = 4095 - value
                  data += newdata
                  if newdata > max:
                      max = newdata
                  if newdata < min:
                      min = newdata
              data -= (max + min)
              data >>= 3
              return round(1024 * data / 4095, 2)
      print(400, Light.analogValue(400))  # 400 923.98
      print(500, Light.analogValue(500))  # 500 898.97
      print(600, Light.analogValue(600))  # 600 873.96
      print(700, Light.analogValue(700))  # 700 848.96
      print(800, Light.analogValue(800))  # 800 823.95
      print(900, Light.analogValue(900))  # 900 798.95
      posted in Units
      maechler
      @lukasmaximus @ajb2k3 Thanks for your support! Although the video does not really answer my question.
      I am able to read values from the PbHUB like this:
      earth = pbhub.analogRead(0x00)
      light = pbhub.analogRead(0x01)
      The problem is, that these values seem to be wrong. The lux value increases when it gets darker, similarly the earth unit says the earth gets dryer when it actually gets wetter. I think the problem is, that reading directly from PbHUB, the logic from the LIGHT.analogValue function is missing:
      class Light:
          @property
          def analogValue(self):
              data = 0
              max = 0
              min = 4096
                  newdata = 4095 - self.adc.readraw()
                  data += newdata
                  if newdata > max:
                      max = newdata
                  if newdata < min:
                      min = newdata
              data -= (max + min)
              data >>= 3
      This function seems to transform the data in a way that is missing when reading the value directly from PbHUB. My question is whether I do have to copy paste this logic or whether there is some way to reuse the LIGHT unit with PbHUB?
      I would like to be able to do something like this:
      earth = unit.get(unit.EARTH, pbhub.HUB0) # Not M5Stack API yet
      light = unit.get(unit.LIGHT, pbhub.HUB1) # Not M5Stack API yet
      # This should read the value correctly, using the `LIGHT.analogValue` logic
      print(earth.analogValue())
      print(light.analogValue())
      posted in Units
      maechler
    • Connect units to PbHUB
      I am trying to connect a LIGHT and an EARTH unit to the PbHUB. I connected the PbHUB to PortA, the EARTH sensor to Hub 0 and the LIGHT sensor to Hub 1.
      My code looks like this:
      I am able to read values from both sensors, however with strange behaviours. E.g. the lux value increases when it gets darker and vice versa. I guess the problem is, that I am lacking the logic of the analogRead function in the LIGHT and EARTH units:
      https://github.com/m5stack/UIFlow-Code/blob/a0dbef98fe29323d6b1837b479764fdab50c3836/units/_light.py
      https://github.com/m5stack/UIFlow-Code/blob/a0dbef98fe29323d6b1837b479764fdab50c3836/units/_earth.py
      However I do not see how I would have to connect this unit correctly to the PbHUB. Do I have to copy paste the analogRead logic or is there another way to connect these units?
      @ajb2k3 Do you know how this should be handled?
      posted in Units
      maechler
    • RE: PaHub Access cracked.
      @ajb2k3 Thanks, it does work with 1.3.5 beta!
      posted in Units
      maechler
      @ajb2k3 I am using a regular M5Stack Core. So which version of UIFlow should I be using?
      posted in Units
      maechler
      @lukasmaximus and @ajb2k3 Thank you very much for your answers!
      I am working with Visual Studio Code and UIFlow-v1.3.2. But I use flow.m5stack.com to look up how to connect the sensors. I was confused because PaHub is greyed out there:
      Thanks for showing how to select the PaHub, however it does still not work for me. Even with the simplest possible example in UI Flow I get the following error: 'module' object has no attribute 'PAHUB0'
      from m5stack import *
      from m5ui import *
      from uiflow import *
      import unit
      setScreenColor(0x000000)
      env1 = unit.get(unit.ENV, unit.PAHUB0)
      If I connect the same unit to unit.PORTA everything works fine. I would like to be able to connect EARTH, ENV and LIGHT units using the PaHub. Is it possible that not all units are supported yet?
      E.g. for the EARTH unit I can not select PaHub using the drop down you showed.
      Thanks for your help!
      posted in Units
      maechler
      Thanks for sharing! Do you also have an example on how to connect multiple sensors to the PaHub and read values from them?
      posted in Units
      maechler
