Thank you very much . work like a charm!!
P
Offline
RE: "Unit Scales" example in github doesn't work
I use m5stack grey with "Unit Scale" link. after using arduino sketch compile and upload code , it shows "scales not connect".
but i use easyloader to burn firmware it works fine.
so what is the difference between them.
and i use i2c to scan it shows 0x26
