@senbayama_no_tanuki
The markdown I added to the code is incorrect, so some content is missing, so I'm reposting the whole code.
#include <M5Unified.h> #include <M5GFX.h> #include <SPI.h> #include <M5Module_LAN.h> //============================================== // 1st M5MODULE-LAN-13.2(M5STACK-BASIC) uint8_t int_pin = 34; // interrupt (input) uint8_t rst_pin = 13; // Reset (output) uint8_t cs_pin = 15; // CableSelect (output) byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0x89}; IPAddress ip(192, 168, 1, 177); IPAddress gateway(192, 168, 1, 1); // Subnet mask(It won't work without this gateway description) IPAddress subnet(255, 255, 255, 0); // Subnet mask(It won't work without this subnet description) //============================================== // 2nd M5MODULE-LAN-13.2(M5STACK-BASIC) uint8_t int_pin2 = 35; // interrupt (input) uint8_t rst_pin2 = 0; // Reset (output) uint8_t cs_pin2 = 5; // CableSelect (output) byte mac2[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xA0}; IPAddress ip2(192, 168, 1, 178); IPAddress gateway2(192, 168, 1, 1); // Subnet mask(It won't work without this gateway description) IPAddress subnet2(255, 255, 255, 0); // Subnet mask(It won't work without this subnet description) M5Module_LAN LAN; M5Module_LAN LAN2; EthernetServer server(8080); EthernetServer server2(8088); void setup() { M5.begin(); M5.Display.begin(); M5.Display.setTextColor(WHITE); M5.Lcd.setTextSize(2); // 1=7,2=14,3=21,4=28,5=35,6=42,7=49PX SPI.begin(SCK, MISO, MOSI, -1); // Initializing the first module LAN.setResetPin(rst_pin); LAN.reset(); LAN.init(cs_pin); pinMode(cs_pin, OUTPUT); pinMode(cs_pin2, OUTPUT); pinMode(rst_pin, OUTPUT); pinMode(rst_pin2, OUTPUT); digitalWrite(cs_pin, LOW); // LOW=enable digitalWrite(cs_pin2, HIGH); // HIGH=disable digitalWrite(rst_pin, HIGH); digitalWrite(rst_pin2, HIGH); Ethernet.begin(mac, ip, gateway, subnet); M5.Lcd.print("1st unit: "); M5.Lcd.println(Ethernet.localIP().toString().c_str()); server.begin(); delay(2); // Initializing the second module LAN2.setResetPin(rst_pin2); delay(10); LAN2.reset(); LAN2.init(cs_pin2); digitalWrite(cs_pin2, LOW); // LOW=enable digitalWrite(cs_pin, HIGH); // HIGH=disable Ethernet.begin(mac2, ip2, gateway2, subnet2); M5.Lcd.print("2nd unit: "); M5.Lcd.println(Ethernet.localIP().toString().c_str()); server2.begin(); } void loop() { // Server 2 Client Process digitalWrite(cs_pin2, LOW); // LOW=enable EthernetClient client2 = server2.available(); if (client2) { while (client2.connected() && client2.available() > 0) { char thisChar = client2.read(); M5.Lcd.print(thisChar); } } digitalWrite(cs_pin2, HIGH); // HIGH=disable // Server 1 Client Process digitalWrite(cs_pin, LOW); LOW=enable EthernetClient client1 = server.available(); if (client1) { while (client1.connected() && client1.available() > 0) { char thisChar = client1.read(); M5.Lcd.print(thisChar); } } digitalWrite(cs_pin, HIGH); // HIGH=disable }
