    2. PRODUCTS
    3. Cores
    4. M5Stack Fire
    • Most Posts
    M5Stack Fire
    • L
      Arduino IDE Rebuilds all the Libraries
      • LordInchcape
      Votes
      114
      Views
      @lordinchcape if you want compiles quickly, you should use platfromIO. Not Arduino IDE
    • E
      COM Problems -> SD Card -> GET/POST
      • Efried
      Votes
      108
      Views
      Hi @Efried are you using micropython/uiflow firmware or arduino? make sure you have installed the cp210x drivers first if you haven't already https://m5stack.com/pages/download I made a few simple tutorials on hackster.io to get started with http requests, hope they can be of use to you. https://www.hackster.io/lukasmaximus89/m5stack-and-mit-app-inventor-47bd32 https://www.hackster.io/lukasmaximus89/m5stack-micropython-simple-web-server-20a4c4
    • J
      Identify M5Stack Fire Revision & Issues
      • jpk
      9
      0
      Votes
      9
      940
      Views
      B
      @jpk Was there ever any response / resolution to this question regarding Fire hardware revision? I just bought a Fire from the M5Stack online store (not Amazon), and it has the same data and rev # (2018 2A). I would also like to know what model IMU is installed.
    • A
      Import error("no module named 'uiflow' ", ) displayed on the M5Stack
      • Alpine-Lake
      Votes
      115
      Views
      @alpine-lake What environment are you programming in?
    • M
      This topic is deleted!
      • Mystereon
      6
      0
      Votes
      6
      67
      Views
    • M
      M5Stack Fire MPU6050 & MAG3110
      • mikeljo
      Votes
      130
      Views
    • M
      Crystal part
      • mukilan
      Votes
      183
      Views
    • S
      Hissing Noise from Loudspeaker
      • scotus
      0
      Votes
      355
      Views
      Due to hardware flaws, sometimes when interfacing with some of the units there is an audible hiss. Unfortunately since it is a hardware flaw the only solution is to use code to reduce the volume of the hiss. in Arduino it should be something like dacWrite(25,0) Python dac0 = machine.DAC(25) dac0.write(0)
    • Y
      Where can I find an example of retrieving data from BMM150 + SH200Q
      • Yova
      0
      Votes
      575
      Views
      Hello @Yova, there is a standard library for SH200Q available for the M5Stick. Since I have a M5Stack Fire core, I ported this library in order to work for this device. You can find it at the address: https://github.com/scavallero/SH200Q. I will put there an example as soon as possible.
    • Fire & Base Node
      • mick
      Votes
      333
      Views
    • P
      Uart 5v tollerant
      • Powersoft
      Votes
      275
      Views
      Yes all grove ports output 5V
    • S
      CE certification details.
      • SandeepUD
      Votes
      262
      Views
    • M5Stack Fire old?
      • yellowelise
      0
      Votes
      794
      Views
      @ajb2k3 Amazon.it
    • E
      M5Stack Core+Base WIFI issue
      • Engin
      Votes
      427
      Views
    • P
      Update m5Stack to 1.3.2
      • patmolloy
      Votes
      394
      Views
      Check your usb cable, sometimes the cables dont work.
    • How to program the M5stack fire RGB LEDs SK6812
      • grelm
      0
      Votes
      614
      Views
      @grelm I would normally have said the adafruit libs but I keep reading that fastled is well, faster. If you look in the docs there should be some listings for the pin outs but normally RGB leds are connected to Grove Port A the red port.
    • F
      M5Stack FIRE - should I return it?
      • fonix232
      11
      0
      Votes
      11
      1883
      Views
      W
      @fonix232 said in M5Stack FIRE - should I return it?: the bottom boards seem to be swollen as well (the bit where the battery is connected to the PCB is pushed and warped upwards, making stacking quite difficult and in some cases, impossible). Seems odd. Can you post a picture? Maybe it’s a result of a swelling battery. There were also some battery issues earlier with their vendor/supplier. Either way, the M5Stack team provides good customer service. I’m sure they will address your problems.
    • L
      M5Stack problem with Connecting to WIFI
      • LordInchcape
      0
      Votes
      756
      Views
      L
      Thinking more about it. Its probably that when the Fire is fully assembled it requires a stronger WiFi signal, perhaps due to the proximity of the other components.
    • T
      M5Stack Fire questions: firmwares and RAM
      • torabora
      Votes
      768
      Views
      T
      @ajb2k3 Thank you very much for your reply!
    • M
      M5 Fire psram setup woes
      • Mikey Wetzel
      Votes
      662
      Views
      @mikey-wetzel You can program in C using the espressif or Arduino but you will need to create your own wifi connect routines
    Move Topic
