  • [RULES] Please READ before posting here!
    Pinned Locked
    5 Votes
    12k Views
  • PSRAM upgrade for the CardputerADV
    2 Votes
    R
    I took a closer look and compared M5StampS3A vs M5StampS3 BAT and I must say that it is not possible to do any piggyback for pin mapping at the M5StampS3A level since ESP32-S3FN8 vs ESP32-S3-PICO-1-N8R8 have differences in the number of GPIOs (6 pins error), see the difference table below: [image: 1774204115000-f8a8e80c-1dca-472a-ab48-dac7e6656c42-image.png] So it only remains for M5Stack team to upgrade M5StampS3A for 2/8 PSRAM, i.e. have M5StampS3B version.
  • Stamp-S3Bat HAT2 Bus
    1 Votes
    R
    In addition, the following screen snippet shows two possible suggestions how the 2x9@2.54mm pins can be assigned. [image: 1774182873732-efd89c09-1cce-4886-8c79-39b9ed5a4d05-image.png]
  • M5Burner for Raspberry Pi 500+
    1 Votes
  • Prototype board for AtomS3R-Ext
    1 Votes
    R
    the following is a screen snippet of this board: [image: 1773945187568-257aff04-e4f1-494f-bec9-7aa804edaf32-image.png]
  • Industrial Analog pH Meter
  • MOSFET unit
    6
    9 Votes
    5k Views
    L
    @teastain can you please share the scheme how to built a MOSFET inside a M5Stack Proto Unit. Thanks
  • Atom with ESP-H2
    2 Votes
  • Tough with larger screen
    tough screen size
    2 Votes
  • [Product] Round shaped Core Controller
  • 0 Votes
  • [MQTT-Core] Support for RETAIN
    8
    5 Votes
    15k Views
    felmueF
    Hello @magister in the mean time you could try and copy the correct Python statement into an Execute mpy code block. You can find it under System. Thanks Felix
  • Core2 Ink Display
    1 Votes
  • Spare parts
  • MQ Unit - additional sensors
    1 Votes
  • Option to compile the UIFlow2 code
    4k Views
    B
    @ajb2k3 I'm not so sure. It is a fairly large request, and probably needs funding. It needs to be initiated by the suppliers, only then it will be directed to the micropython writers.
  • Code acceleration options
    1 Votes
    1k Views
  • [New Firmware]StamPLC internal firmware support OTA update
  • CardPuter clamshell edition!
    1 Votes
    1k Views
  • [Product Revision] Tube/Air Pressure Unit with I2C
    7
    8 Votes
    7k Views
    K
    @Maethaxi Thanks I was looking for a Tube/Air Pressure unit with a I2C interface... I was trying to use the M5Stack Tube/Air Pressure Unit but I am running into an issue so I figured I would look for other options if I can't get it to work accurately... I need a sensor sensitive enough to detect someone blowing lightly in a tube....
