Same problem here. Program become non-responsive, requires Force Quit.
Boomvalt
@Boomvalt
Posts made by Boomvalt
RE: M5Burner does not work in MacOX 12.3.
PaHUB + ENVIII pressure reading issue
Using an Atom Matrix with a PaHUB, a TVOC/eCO2 unit and an ENVIII gives a strange pressure result.
The pressure value reads about 5 times the actual pressure level. This is the same whether the ENV is solo, or the other sensor is connected. Other readings seem to be working as expected,
When the ENVIII is connected on its own the pressure readings are as expected.
from m5stack import *
from m5ui import *
from uiflow import *
import wifiCfg
from m5mqtt import M5mqtt
import time
import unitrgb.set_screen([0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0xFFFFFF,0,0,0,0])
tvoc_2 = unit.get(unit.TVOC, unit.PAHUB1)
pahub_0 = unit.get(unit.PAHUB, unit.PORTA)
env3_0 = unit.get(unit.ENV3, unit.PAHUB0)tempdata = None
humdata = None
pressdata = None
iapbase = None
tvoc = None
basetvoc = None
co2 = None
baseco2 = None
h2 = None
eth = NonewifiCfg.doConnect('', '')
m5mqtt = M5mqtt('atomenv', '192.168.178.14', 1883, '', '', 600)
m5mqtt.start()
tvoc_2.set_iaq_baseline(35187, 35502)
while True:
tempdata = env3_0.temperature
humdata = env3_0.humidity
pressdata = env3_0.pressure
m5mqtt.publish(str('temperature'),str(tempdata))
m5mqtt.publish(str('humidity'),str(humdata))
m5mqtt.publish(str('pressure'),str(pressdata))
wait(2)
iapbase = tvoc_2.get_iaq_baseline()
tvoc = tvoc_2.TVOC
basetvoc = tvoc_2.baseline_TVOC
co2 = tvoc_2.eCO2
baseco2 = tvoc_2.baseline_eCO2
h2 = tvoc_2.H2
eth = tvoc_2.Ethanol
m5mqtt.publish(str('IAPbaseline'),str(iapbase))
m5mqtt.publish(str('TVOCnow'),str(tvoc))
m5mqtt.publish(str('TVOCbase'),str(basetvoc))
m5mqtt.publish(str('CO2'),str(co2))
m5mqtt.publish(str('CO2base'),str(baseco2))
m5mqtt.publish(str('H2'),str(h2))
m5mqtt.publish(str('ethanol'),str(eth))
wait_ms(2) -
RE: UIFlow 1.8.7
Getting issues with UIFlow Desktop IDE. -1.8.7
M5 Atom Matrix.
Persistent crash when creating screen object and using the colour palette.2015 iMac macOS Monterey v 12.01
