    SPI clash between LCD and nRF24L01
    PRODUCTS
    14
    39.9k
      skelstar
      For what it's worth commenting out the two lines in the post above didn't fix it. I also tried writing LOW to LCD_CS (before writing) then HIGH to disable (after writing) and that did not fix it either.
      Going to try using a different LCD library.
        skelstar
        @m5stack any ideas about this? I shouldn't have any issues using other devices that use SPI should I?
        Thanks!
          sibtcha
          Hello, It seems like I have a problem similaire has yours... I would like to use à MAX6675 to get temperature from a Thermocouple K, but this board use SPI.
          When I test my code in a ESP32, it's OK. When I test my code in the M5Stack without the M5.begin(), it's ok, but when I include de M5.begin, the value returned by the MAX6675 are 0
          Is there any solution ?
          • JJJ
            JJ @sibtcha
            @sibtcha Hi Sibtcha,
            I haven't tried using a thermocouple with the M5Stack..... I don't think Skelstar has been here in a while.... Perhaps post your code... someone may notice a problem.
              sibtcha
              @JimiT You're right. Here is my code and the result when M5 lib is included or not
              #include <Adafruit_MAX31855.h>
              //#include <M5Stack.h>
              // Example creating a thermocouple instance with software SPI on any three digital IO pins.
              #define MAXDO   19
              #define MAXCS   17
              #define MAXCLK  18
              Adafruit_MAX31855 thermocouple(MAXCLK, MAXCS, MAXDO);
                //M5.begin();
                Serial.begin(115200);
                Serial.print("Internal Temp = ");
                Serial.println(thermocouple.readInternal());
                while (!Serial) delay(1); // wait for Serial on Leonardo/Zero, etc
                Serial.println("MAX31855 test");
                // wait for MAX chip to stabilize
                delay(2000);
                // basic readout test, just print the current temp
                double c = thermocouple.readCelsius();
                if (isnan(c)) {
                  Serial.println("Something wrong with thermocouple!");
                } else {
                  Serial.print("C = ");
                  Serial.println(c);
                delay(1000);
                //M5.update();
              And the result is
              Internal Temp = 32.50
              C = 17.25
              Internal Temp = 32.56
              C = 15.25
              C = 18.25
              C = 16.50
              C = 17.25
              Internal Temp = 32.63
              C = 18.50
              C = 18.25
              But if I uncomment the line 3 lines to include M5 to the projet, the result is:
              Internal Temp = 0.00
              C = 0.00
              C = 0.00
              C = 0.00
              C = 0.00
              C = 0.00
              C = 0.00
              I think is something about the SPI, but I'm not sure. I try to use other pins but unfortunately unsucessfully
              • JJJ
                JJ @sibtcha
                @sibtcha At the very top of the code it should have:
                #include <SPI.h>
                That file should already be on your system if you followed standard setup for the M5Stack - it should be located in:
                C:\Users\YOUR USER NAME\Documents\Arduino\hardware\espressif\esp32\libraries\SPI\src
                Perhaps give that a try with the M5Stack commands enabled.
                Further tweaks may be required....
                  sibtcha
                  Thank you @JimiT
                  Indeed I forgot to include the SPI lib, but unfortunetaly the result isn't good. The values jump between positive and negastives and I do nothing.
                  Internal Temp = 68.12
                  Internal Temp = -111.87
                  Internal Temp = 33.75
                  Internal Temp = -120.00
                  C = 1548.50
                  C = 530.00
                  Internal Temp = 33.56
                  • reaper7R
                    reaper7
                    @sibtcha , try to initialize Adafruit_MAX31855 library only with CS pin:
                    Adafruit_MAX31855 thermocouple(MAXCS);
                    as You see at library source: https://github.com/adafruit/Adafruit-MAX31855-library/blob/master/Adafruit_MAX31855.cpp
                    when You declare SPI CLK line then library try read this device by software SPI implementation!
                    also You are forgot thermocouple.begin();
                      sibtcha
                      @reaper7 在 SPI clash between LCD and nRF24L01 中说:
                      Thank you for the reply.
                      Wich pin do you think I have to use for the CS ? No matter wich one ? In the MAX31855 I've 5 pins
                      • GND
                      • VCC (3v3)
                      • DO
                      • CS
                      • CLK
                      If I only initialize the object with the CS, what must I do with the other pins (DO and CLK) ?
                      Sorry for this question, but I'm a begginer
                      • reaper7R
                        reaper7
                        Phisically connect Your MAX to SPI lines and CS leave connected as is!
                        M5Stack pinout:
                        https://github.com/m5stack/M5Stack#pinout
                        MAX DO -> M5Stack MISO (GPIO19)
                        MAX CS -> M5Stack GPIO17
                        MAX CLK -> M5Stack CLK (GPIO18)
                        Looks like You have connection prepared corectly...
                        Change only Your sketch like this:
                        #include <SPI.h>
                        //#define MAXDO   19
                        //#define MAXCLK  18
                        #define MAXCS   17
                          //M5.begin();
                          delay(2000);
                          if (isnan(c)) {
                          } else {
                            Serial.println(c);
                          delay(1000);
                          //M5.update();
                          sibtcha
                          thank you for your reply. I'v tried to only use the CS pin and it works, but... yes, there is always a but :-) the results are not very accurate. From the moment a set a brightness in the screen, the values of the temperatures grows.
                          I try to read the temp in a separate task, but it didn't change anything.
                          Here is my code
                          #include "Adafruit_MAX31855.h"
                          #include <SPI.h>
                          // digital IO pins.
                          #define MAXCS   17
                          void task1(void * pvParameters) {
                            for (;;) {
                              float avg = 0;
                              /* Read nbReadToAvg times to make an average of the temp */
                              for (int i = 0; i < nbReadToAvg; i++) {
                                float c = thermocouple.readCelsius();
                                avg = avg + c;
                                delay(100);
                              avg = avg / nbReadToAvg;
                              Serial.println(avg);
                            Serial.print("MOSI=");
                            Serial.println(MOSI);
                            Serial.print("MISO=");
                            Serial.println(MISO);
                            Serial.print("SCK=");
                            Serial.println(SCK);
                            Serial.print("SS=");
                            Serial.println(SS);
                            Serial.println("MAX31855 Initializing ...");
                            //  M5.Lcd.setTextColor(WHITE, BLACK);
                            delay(1000);
                            xTaskCreatePinnedToCore(
                              task1,
                              "task1",
                              4096,
                              NULL,
                              1,
                              NULL,
                              0
                            Serial.println("M5 begin without LCD");
                            M5.begin(false, false);
                            delay(10000);
                            Serial.println("LCD Start");
                            M5.Lcd.begin();
                            for(int j=0;j<100;j++) {
                              //Serial.printf("Brigthness=%d\n", j);
                              M5.Lcd.setBrightness(j);
                              delay(200);
                            //delay(10000);
                            Serial.println("LCD Shutdown set Brightness to 20");
                            M5.Lcd.setBrightness(10);
                            //M5.Lcd.sleep();
                            M5.Lcd.setTextSize(4);
                            M5.Lcd.print("test");
                            M5.update();
                          And here is the result :
                          20.27
                          20.50
                          20.35
                          20.45
                          20.27
                          18.52
                          20.12
                          20.58
                          20.42
                          LCD Start
                          20.27
                          18.60
                          21.55
                          22.73
                          21.58
                          21.77
                          21.98
                          20.87
                          21.40
                          22.40
                          21.65
                          23.60
                          23.40
                          24.02
                          24.48
                          24.62
                          24.55
                          29.67
                          26.83
                          25.52
                          29.15
                          23.48
                          22.27
                          22.15
                          21.50
                          22.92
                          20.50
                          21.67
                          22.60
                          21.92
                          22.12
                          22.42
                          Why can see that between the line LCD start and the LCD shutdown, the temperature grows and that why the brightness of the screen is increasing. After the line "LCD Shutdown" the brightness is set to 20 and the value are higher that the values at the beginning but they don't moved.
