    UIFlow 1.6.3
    Official Updates
    9
    19
    28.3k
    • SkinkS
      Skink
      @m5stack
      UiFlow Beta Core2 ,
      here nothing can be selected under Hardware function Power
        ajb2k3 @Skink
        @skink said in UIFlow 1.6.3:
        @m5stack
        UiFlow Beta Core2 ,
        Just tried and it works for me. What exactly is not happening?
        • SkinkS
          Skink @ajb2k3
          Ah, that seems to be a problem in the language German in the English everything works.
          1. picture Core 2 Language "English
          2. picture Core 2 Language "German"
          In the English version I have several options under Hardware Power which I can select.
          In the german version these are missing and the two that are displayed are on top of each other and cannot be selected !!
            @m5stack there is an alignment issue with the German version of the Web UIFlow, looks like the formatting has been broken.
            • V
              veryalien
              The vibration motor intensity setting has no effect. Setting it to any value between 0 and 100 does not change the motor at all. The motor is always fully on when it is enabled.
              • m5stackM
                m5stack @ajb2k3
                @ajb2k3 thanks feedback. we will fix it ASAP
                • K
                  klapaucius
                  This may be a super stupid question but where are the download links for the recent firmwares ?
                  On MacOS, M5burner shows just and empty screen. The flow.m5stack.com site does not show firmware download links (just links to the m5burner tool containing no firmware).
                  https://github.com/m5stack/M5Stack-Firmware/blob/master/firmware-repo.list only shows outdated firmware (which I can upload manually using the flash.sh script after sufficient massaging).
                  Also note that the UIflow desktop app does not seem to work - it looks like the baud rate might be too high for the mac.
                  Thanks in advance for clarifying!
                  • K
                    kurthofman
                    Hello, I've upgraded my M5Stack Fire too 1.6.3 but the device doesn't boot anymore.
                    I get :
                    E (433) esp_image: invalid segment length 0xffffffff
                    E (433) boot: Factory app partition is not bootable
                    E (433) boot: No bootable app partitions in the partition table
                    Can this be solved !
                      ajb2k3 @kurthofman
                      @kurthofman to you upgrade to the correct version of 1.6.3?
                      there is 3 versions for the core
                      • K
                        klapaucius @ajb2k3
                        Is there a download link for the latest firmwares ? The M5burner on MacOS seems broken (I can into details if you want me to), but I can flash firmware manually without problems. But I can't find download links published anywhere.
                        Many thanks in advance!
                        • K
                          klapaucius @ajb2k3
                          • SkinkS
                            Skink
                            @kurthofman
                            Here is a breakdown of the versions for the respective M5 Core's
                            what I don't know exactly is if M5 Core Lite and M5GO are not also part of M5Core Fire.
                            • SkinkS
                              Skink @veryalien
                              @veryalien
                              Yes I have to agree with you, I have the same problem.
                              With "Set vibration intensity" alone the vibration motor does not work at all, no matter if 1-100%.
                              If I switch it on with "Set vibration enable (true)" the motor will vibrate but with the same intensity, I try to change the intensity with "Set vibration intensity" but nothing happens.
                              I can only switch it off with "Set vibration enable (false)"!
                                ajb2k3 @Skink
                                @skink the lite and the go are Mark 1 cores
                                • G
                                  GMAN
                                  Bug report: firmware 1.6.3-en is not installing on M5 stack core (black) 1.6.2 does.
                                  • m5stackM
                                    m5stack @GMAN
                                    @gman what is your mean? can't install the firmware file? or can't burn the firmware? could you say more detail?
