    PROJECTS
    25
    89
    417.3k
    • frittnaF
      frittna @yashax
      @yashax said in Bitcoin / Multi Crypto Coin Ticker with 24 candlesticks chart:
      The new M5Burner does not allow to select the zip file to burn.
      what do you mean?.. try downloading new from source and follow readme
      • Y
        yashax
        • frittnaF
          frittna @yashax
          Thank you. What is the location of the M5Burner source?
          you find the link is in the first post
          download project: https://github.com/frittna/Crypto_Coin_Ticker
          • F
            frankchau93 @frittna
            @frittna
            Hi there,
            I have a Core 2 and I want to install this. I tried doing this on windows with the installer, however the SD card library isn't compatible with the Core 2, according to this post: https://github.com/frittna/Crypto_Coin_Ticker/issues/3
            Can you compile a version with a SD card library that works? This looks so cool and i really want to try this out!
            • frittnaF
              frittna @frankchau93
              @frankchau93
              i started from zero too so maybe give it a try and search/test if there are other compatible libraries. Since i have no core2 device and beside the (stupid) fact that i cannot use the latest boardmanager (higher than 1.0.4) on a core1 I am kind of stuck. But i guess not forever.. atm i am not really plessed with free time but we would need to know what is causing the problems with boardmanager 1.0.5 and higher first. I suspect the WIFI, the SDCard or the Websockets library. Then only minor changings in code are needed to support core2 i guess.
              • Y
                yashax
                Can someone please help me figure out how to display ticker for TIME crypto coin?
                • Y
                  yashax
                  Is it possible to have ticker rotate between several crypto coins? Like BTC for 5 seconds, the ETH for 5 seconds, in the loop.
                  • frittnaF
                    frittna @yashax
                    @yashax
                    regarding TIME token - I see 4 different tokens with that name but none of it is listed on binance.
                    An optional cycling function like you're asking was added in the last version i've released a month ago.
                    Scroll up or go to the github source page.
                    btw: do you have a core1 unit now?
                    • Y
                      yashax @frittna
                      @frittna Yes, picked up 2 Core 1’s with stands. ))
                      Regarding TIME, so if it’s not listed on Binance, it won’t work?
                      Thank you for all your help.
                      J
                      • frittnaF
                        frittna @yashax
                        @yashax
                        yes, thats correct since prize data comes from the binance api only, spot markets, no derivates
                        • Y
                          yashax
                          How can I change clock from 24hr to 12hr?
                          Thank you
                          • frittnaF
                            frittna @yashax
                            you can check at line 500 in the code and simply change lines where is says "time(now)" to "timeFormat12(now)"
                            this will work and will show time in am/pm mode and not in 24h mode.
                            If you want to have a visualisation for am/pm too you would have to find free space first and draw something small with a the isAM() or isPM() function.
                            • Y
                              yashax @frittna
                              @frittna Thank you so much.
                              What’s the while line on the chart?
                              • frittnaF
                                frittna @yashax
                                @yashax
                                the white line is the relative trading volume from the last 24 shown candles
                                • Y
                                  yashax @frittna
                                  @frittna Can you please be kind to help me to adapt your code to display the Forex market, the same way.
                                  Thank you so very much in advance.
                                  • D
                                    dssguy1
                                    Recently my ticker just went to 0.00e+00 for BTC price and no chart. It says "WS Disconnected" now. Did something in the data source change to break this awesome little ticker?
                                    • D
                                      dssguy1
                                      Forgot to mention, it also says "No JSON in response".
                                      • B
                                        bucket62
                                        I am also getting the W.S disconnected and no JSON message. Is there a way to update the config file so that users can change the API? I think this may be a problem with the binance API
                                        • frittnaF
                                          frittna
                                          maybe it could be geo-blocked because here from the EU for example it still works normally!
                                          please test:
                                          https://api.binance.com/api/v3/depth?symbol=BTCUSDT&limit=1000
                                          and
                                          https://api.binance.us/api/v3/depth?symbol=BTCUSDT&limit=1000
                                          If only the .us domain works for you i will update the code soon for an .us version.
                                          If you compile it yourself with arduino you have to modify the .com to .us - so change these two lines:
                                          const char restApiHost = "api.binance.us";
                                          and
                                          const char wsApiHost = "stream.binance.us";
                                            Hello @frittna
                                            FWIW: here in Switzerland both URLs work for me.
