    89 Posts 25 Posters 452.1k Views 10 Watching
    • frittnaF Offline
      frittna @frankchau93
      @frankchau93
      i started from zero too so maybe give it a try and search/test if there are other compatible libraries. Since i have no core2 device and beside the (stupid) fact that i cannot use the latest boardmanager (higher than 1.0.4) on a core1 I am kind of stuck. But i guess not forever.. atm i am not really plessed with free time but we would need to know what is causing the problems with boardmanager 1.0.5 and higher first. I suspect the WIFI, the SDCard or the Websockets library. Then only minor changings in code are needed to support core2 i guess.
      • Y Offline
        yashax
        Can someone please help me figure out how to display ticker for TIME crypto coin?
        • Y Offline
          yashax
          Is it possible to have ticker rotate between several crypto coins? Like BTC for 5 seconds, the ETH for 5 seconds, in the loop.
          • frittnaF Offline
            frittna @yashax
            @yashax
            regarding TIME token - I see 4 different tokens with that name but none of it is listed on binance.
            An optional cycling function like you're asking was added in the last version i've released a month ago.
            Scroll up or go to the github source page.
            btw: do you have a core1 unit now?
            • Y Offline
              yashax @frittna
              @frittna Yes, picked up 2 Core 1’s with stands. ))
              Regarding TIME, so if it’s not listed on Binance, it won’t work?
              Thank you for all your help.
              J
              • frittnaF Offline
                frittna @yashax
                @yashax
                yes, thats correct since prize data comes from the binance api only, spot markets, no derivates
                • Y Offline
                  yashax
                  How can I change clock from 24hr to 12hr?
                  Thank you
                  • frittnaF Offline
                    frittna @yashax
                    you can check at line 500 in the code and simply change lines where is says "time(now)" to "timeFormat12(now)"
                    this will work and will show time in am/pm mode and not in 24h mode.
                    If you want to have a visualisation for am/pm too you would have to find free space first and draw something small with a the isAM() or isPM() function.
                    • Y Offline
                      yashax @frittna
                      @frittna Thank you so much.
                      What’s the while line on the chart?
                      • frittnaF Offline
                        frittna @yashax
                        @yashax
                        the white line is the relative trading volume from the last 24 shown candles
                        • Y Offline
                          yashax @frittna
                          @frittna Can you please be kind to help me to adapt your code to display the Forex market, the same way.
                          Thank you so very much in advance.
                            dssguy1
                            Recently my ticker just went to 0.00e+00 for BTC price and no chart. It says "WS Disconnected" now. Did something in the data source change to break this awesome little ticker?
                              dssguy1
                              Forgot to mention, it also says "No JSON in response".
                              • B Offline
                                bucket62
                                I am also getting the W.S disconnected and no JSON message. Is there a way to update the config file so that users can change the API? I think this may be a problem with the binance API
                                • frittnaF Offline
                                  frittna
                                  maybe it could be geo-blocked because here from the EU for example it still works normally!
                                  please test:
                                  https://api.binance.com/api/v3/depth?symbol=BTCUSDT&limit=1000
                                  and
                                  https://api.binance.us/api/v3/depth?symbol=BTCUSDT&limit=1000
                                  If only the .us domain works for you i will update the code soon for an .us version.
                                  If you compile it yourself with arduino you have to modify the .com to .us - so change these two lines:
                                  const char restApiHost = "api.binance.us";
                                  and
                                  const char wsApiHost = "stream.binance.us";
                                    Hello @frittna
                                    FWIW: here in Switzerland both URLs work for me.
                                    • frittnaF Offline
                                      frittna
                                      i uploaded a version that uses binance.us.
                                      Use the M5Burner in my Zip File on Github
                                      • B Offline
                                        bucket62 @frittna
                                        @frittna
                                        Thank you frittna! I am in the U.S. and will try that out today. I will report back if it works.
                                        • B Offline
                                          bucket62
                                          Hi Frittna, thank you for your help. The Binance.US api fixed the problem and I am back up and running. Thank you!
                                            dssguy1
                                            Works perfect! THANKS!!! Now I can watch myself losing money again!
