    A few questions about the stepper motor model.
    PRODUCTS
    7.0k
      @m5stack Would you mind answering a few questions on the construction of the stepper motor module.
      Q1, Where is the arduino?
      Q2, are the stepper drivers soldered to the main board?
      • m5-docsM
        m5-docs
        Hello ajb2k3,
        A1: here is the arduino example
        https://github.com/m5stack/stepmotor_module/tree/master/Example/StepMotor_M5test
        A2: The stepmotor module can be stacked below the main board. They communicate with each other through I2C. The I2C address of stepmotor module is 0x70 by default.
        M5Stack documentation URL
        https://docs.m5stack.com
          ajb2k3 @m5-docs
          @watson 在 A few questions about the stepper motor model. 中说:
          Hello ajb2k3,
          Thats not the answers to what I asked.
          Ok I will try again.
          Q1 where is the Arduino (atmega 328) located on the module.
          Q2 Are the Stepper Motor driver's soldered directly to the M5Stepper module PCB?
          • m5-docsM
            m5-docs @ajb2k3
            A1 here is the document and picture about stepmotor module
            https://m5stack.github.io/m5-docs/#/en/product_documents/modules/module_stepmotor
            A2 Yes, soldered to PCB
              ajb2k3 @m5-docs
              Thanks, I wondered why I could not move them or find the atmega.
              Thank you.
