    ADC Module not working in UIflow2 - [fixed]
    UiFlow 2.0
    3.4k
      smatlok
      Setup: New UIF2 Project, Core2, only adding an external ADC Unit (and calling value in loop)
      Problem: I2C Bus initializes, but the "Init adc_0" Block fails in a debug error: "ValueError: expecting a pin" on the display. The error referres to line "adc_0 = ADC(i2c0)".
      So, sound like function "ADC()" does not accept the i2c0 handler.
      How to proceed/fix? thank you! :)
        If you ha a Twitter/X/whatever its called account, post it there with @m5stack
        @M5Stack confirmed.
        here is the console output
        MicroPython v1.20.0 on 2023-08-04; M5STACK with ESP32S3
        >>> import gc
        >>> gc.collect()
        === import os, sys, io
        === import M5
        === from M5 import *
        === from hardware import *
        === from unit import *
        === label0 = None
        === i2c0 = None
        === adc_0 = None
        === def setup():
        ===   global label0, i2c0, adc_0
        ===   i2c0 = I2C(0, scl=Pin(1), sda=Pin(2), freq=100000)
        ===   adc_0 = ADC(i2c0)
        ===   M5.begin()
        ===   Widgets.fillScreen(0x222222)
        ===   label0 = Widgets.Label("Text", 64, 71, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
        === def loop():
        ===   M5.update()
        ===   label0.setText(str(adc_0.get_raw_value()))
        ===   try:
        ===     setup()
        ===     while True:
        ===       loop()
        ===     try:
        ===       print_error_msg(e)
        ===     except ImportError:
          File "<stdin>", line 22, in <module>
          File "<stdin>", line 12, in setup
        • lbuqueL
          lbuque
          @smatlok @ajb2k3 There is an ADC class in the unit module, which is the abstract class of the ADC unit, and it conflicts with the class name of machine.ADC. It will be fixed in the next version.
            Machine ADC if for adc readings from the pins directly where as the Unit ADC uses defined port pins.
              smatlok @lbuque
              @lbuque Great, thanks a lot, it works now (alpha23) :) and thanks @ajb2k3 for checking and confirming!
