    195 Posts 79 Posters 570.3k Views 13 Watching
    • Coopersmith-24601C Offline
      Coopersmith-24601
      FEATURE REQUEST!
      It would be extraordinarily helpful for there to be a type of LABEL in UiFlow2 which could fill the screen and word-wrap long text strings.
      • IAMLIUBOI Offline
        IAMLIUBO @Coopersmith-24601
        @Coopersmith-24601 said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
        FEATURE REQUEST!
        Yes. Thanks for suggestion. We will consider this.
          Calvorotas
          I am trying to receive a bytearray via BLE from a server, but I can't get a response.
          By sending a certain bytearray via BLE to the Sbrick device, it returns a response indicating the temperature value. And through another bytearray, the voltage value is returned.
          In App Inventor I get it with these blocks:image-1.png image-2.png
          But in UiFlow 2.0 I can't get it using these blocks:
          What am I doing wrong?
          s it possible that this block will not trigger the server response?
          Perhaps, the mode argument is mode=0 (write-without-response). Or am I mixing up different things?
          I can't get a response from the server with the "When BLE client on notify" block or with the "When BLE client on read complete" block
          I need help, or a lot of help. :)
          Thank you very much.
          • greenleafG Offline
            greenleaf
            Feature request:
            Ability to set headers for Label+ objects. Many APIs required these headers before they respond with proper JSON.
            Example:
            curl -H "Accept: application/json" https://icanhazdadjoke.com/
              Rango
              I'm using a MiniJoyC with M5stuckC Plus2 and UIFlow 2.1.4.
              I've read through examples and documentation but I can not get x or y values. They only display 0.
              Same thing happens in Arduino IDE.
              I do get values when using UI flow 1, so I know the minijoy is working.
              Any known issues with the UIf2 libraries?
              Thanks in advance.
              • G Offline
                gbelfor
                Using: UIFlow 2.1.5, AtomS3, KMeterISOunit
                From the version history, it appears that the Firmware changed the KMeterISOunit API a couple revs back, but UIFlow is still generating code for the old API. When I do the blockly code and run on my AtomS3, an exception is thrown showing the issue:
                Code generated (snipit)
                ...but from the latest API docs, the reading code should be:
                Note: I did a workaround using the "Execute mpy code" block and writing in the proper API calls, but it would be nicer if the versions matched up.
                • X Offline
                  xs
                  Are GoPlus2 module not supported in UiFlow2? Do you plan to add support?
                  • X Offline
                    xs @xs
                    @xs Also, Servo2 module isnt sopported
                    • ? Offline
                      A Former User
                      Hello, could you add more RTC blocks to Uiflow2? Like the ones in Uiflow1? I'm a beginner and I wanted to make a simple clock app for the cardputer but for now seems impossible for me without learning to code. Also it would be nice to have all the apps I built in the App.list section of Uiflow2 on my cardputer. Thanks! Screenshot 2024-11-17 194153.png
                      cryptospokC 1 Reply Last reply Reply Quote 1
                      • cryptospokC Offline
                        cryptospok
                        I'm using UIFlow2 on Microsoft Edge and when I try to create a variable with the name of an object that already exists, I get the conflict information and even if I correct it, when I exit the variable creation window, UIFlow2 crashes and I have to reload the page to continue.
                          cryptospok @Guest
                            riztronic
                            missing magnetometer scratch code for atom s3r , please add
                            kurikoK teastainT 2 Replies Last reply Reply Quote 0
                            • kurikoK Offline
                              kuriko @riztronic
                              @riztronic
                              did you mean a built-in magnetometer?
                              • teastainT Offline
                                teastain @riztronic
                                @riztronic The device includes a 5V to 3.3V power circuit, a built-in three-axis BMM150 geomagnetic sensor,
                                  Calilov330000
                                  Does anyone know how to connect my m5stack core 2 ?
                                  Im using the raspberry pi 5. Is the m5stackbcore 2 plug and play with raspberry pi or the websites? Ive neen trying to connect this thing for 2 weeks. This is crazy it takes this much trouble
                                  • kurikoK Offline
                                    kuriko @Calilov330000
                                    @Calilov330000
                                    why don't you try a simple laptop/desktop?
                                      Davidalan5757
                                      Could you unlock from UIFlow 2 the capability to code in micropython…
                                        jpilarski
                                        I am looking for all of the lcd drawing tools that were available in uiflow1.0. I was making some interactive graphics and I was drawing lines or rectangles in a loop and doing that in uiflow2.0 requires you to first drag out 100 lines in the ui builder which just is too slow. Here are the bloacks I am looking for in uiflow 2.0. How can I do something similar in uiflow 2.0 Screenshot 2025-02-18 235307.png
                                          charlesRD
                                          I have some difficulties to burn UIFLOW on new devices
                                          For ATom lite it seems to work but i get ERROR The device type is unknown! on device manager.
                                          I dont know if it can acces to the wifi. i tried several time to unregister and burn it again, reinstall M5 burner, but it doesn't help.
                                          It can't connect to my M5 stamp C3, maybe there is a way to make a factory reset on them?
                                          The previous Atom and Stick set up in february still worked well, and appears with green dot on device manager. when i try to burn it now i get the "unknown type" error and red dot.
                                          it looks like i am not able anymore to have the same atom running when i burn them today.
                                          Did i forgot something ?
                                          Thank you very much,
                                          Charles
                                          • Y Offline
                                            yaleman
