    UiFlow 2.0
    76
    190
    473.9k
      A Former User
      Hello, could you add more RTC blocks to Uiflow2? Like the ones in Uiflow1? I'm a beginner and I wanted to make a simple clock app for the cardputer but for now seems impossible for me without learning to code. Also it would be nice to have all the apps I built in the App.list section of Uiflow2 on my cardputer. Thanks! Screenshot 2024-11-17 194153.png
      cryptospokC 1 Reply Last reply Reply Quote 1
      • cryptospokC
        cryptospok
        I'm using UIFlow2 on Microsoft Edge and when I try to create a variable with the name of an object that already exists, I get the conflict information and even if I correct it, when I exit the variable creation window, UIFlow2 crashes and I have to reload the page to continue.
        • cryptospokC
          cryptospok @A Former User
          • R
            riztronic
            missing magnetometer scratch code for atom s3r , please add
            kurikoK teastainT 2 Replies Last reply Reply Quote 0
            • kurikoK
              kuriko @riztronic
              @riztronic
              did you mean a built-in magnetometer?
              • teastainT
                teastain @riztronic
                @riztronic The device includes a 5V to 3.3V power circuit, a built-in three-axis BMM150 geomagnetic sensor,
                • C
                  Calilov330000
                  Does anyone know how to connect my m5stack core 2 ?
                  Im using the raspberry pi 5. Is the m5stackbcore 2 plug and play with raspberry pi or the websites? Ive neen trying to connect this thing for 2 weeks. This is crazy it takes this much trouble
                  • kurikoK
                    kuriko @Calilov330000
                    @Calilov330000
                    why don't you try a simple laptop/desktop?
                    • D
                      Davidalan5757
                      Could you unlock from UIFlow 2 the capability to code in micropython…
                      • J
                        jpilarski
                        I am looking for all of the lcd drawing tools that were available in uiflow1.0. I was making some interactive graphics and I was drawing lines or rectangles in a loop and doing that in uiflow2.0 requires you to first drag out 100 lines in the ui builder which just is too slow. Here are the bloacks I am looking for in uiflow 2.0. How can I do something similar in uiflow 2.0 Screenshot 2025-02-18 235307.png
                        • C
                          charlesRD
                          I have some difficulties to burn UIFLOW on new devices
                          For ATom lite it seems to work but i get ERROR The device type is unknown! on device manager.
                          I dont know if it can acces to the wifi. i tried several time to unregister and burn it again, reinstall M5 burner, but it doesn't help.
                          It can't connect to my M5 stamp C3, maybe there is a way to make a factory reset on them?
                          The previous Atom and Stick set up in february still worked well, and appears with green dot on device manager. when i try to burn it now i get the "unknown type" error and red dot.
                          it looks like i am not able anymore to have the same atom running when i burn them today.
                          Did i forgot something ?
                          Thank you very much,
                          Charles
                          • Y
                            yaleman
                              sgu @charlesRD
                              @charlesRD
                              i have similar issues
                              the Tab5 does not burn UIFlow at all!
                                sgu
                                When Will LVGL be integrated in UIFlow 2 ? I don't see a progress there for many months. The new devices such as Tab5 are useless without LVGL. Programming with UiFlow 2.0 and printing simple lines and squares look very old school.
                                • H
                                  hacxx Banned
                                  Thanks for sharing the UiFlow 2.0 resources! I appreciate having a dedicated space for bugs, how-tos, and feature requests. Does anyone have tips on avoiding common firmware burning errors, especially with account binding? Also curious if there’s a timeline for the full API docs release. Looking forward to seeing how this evolves!
                                  • T
                                    thecuri
                                    I recently los all my private cloud projects....is there a way to get them back from your servers?
                                    • Z
                                      zhumingqi
                                      I used UIFlow2 to devleop a simple UI demo, and I monitor the free memory with gc.mem_free(). I found the free memory reduced continiously though I called gc.collect() every loop. Finally, the UI can not update again, but the loop still was running.
                                      Z 1 Reply Last reply Reply Quote 0
                                      • Z
                                        zhumingqi @zhumingqi
                                        I tested more UI design. And I found that the memory leak only happens when I use image component and switch images frequently. Is that a UIFlow2.3.3 bug or my design is incorrect?
                                        • Z
                                          zhumingqi
                                          Today, I updated the UIFlow to V2.3.4, and burned V2.3.4 firmware as well. Then I tested that image component again with M5GFX in UIFlow 2.3.4. But the issue still exists. After I switch two JPG pics with one image component for sometime, the memory will reduced continiously. Finally, the system will break out. And I try to use gc.collect() after every drawImage(), but it's not useful.
                                          Here is my design and python code:
                                          import os, sys, io, gc
                                          import M5
                                          from M5 import *
                                          ImageSwitchFlag = None
                                          def GcCollectAndPrint():
                                          global ImageSwitchFlag
                                          gc.collect()
                                          print(gc.mem_free())
                                          pass
                                          def btnA_wasClicked_event(state):
                                          if ImageSwitchFlag == 0:
                                          M5.Lcd.drawImage("/flash/res/img/RotaryBGBacklight.jpg", 0, 0)
                                          GcCollectAndPrint()
                                          ImageSwitchFlag = 1
                                          elif ImageSwitchFlag == 1:
                                          M5.Lcd.drawImage("/flash/res/img/RotaryBGBT.jpg", 0, 0)
                                          GcCollectAndPrint()
                                          ImageSwitchFlag = 0
                                          def setup():
                                          M5.begin()
                                          Widgets.fillScreen(0x000000)
                                          BtnA.setCallback(type=BtnA.CB_TYPE.WAS_CLICKED, cb=btnA_wasClicked_event)
                                          ImageSwitchFlag = 0
                                          def loop():
                                          M5.update()
                                          if name == 'main':
                                          try:
                                          setup()
                                          while True:
                                          loop()
                                          try:
                                          print_error_msg(e)
                                          except ImportError:
                                          print("please update to latest firmware")******
                                            Schwibach
                                            I wrote in another thread about my Sync... 0% problem.
                                            I am pretty sure now that it is a bug. I does not matter which program I use. I can run them from UIFlow 2.0. But as soon as I download a program, I will get the Sync... 0%
                                            Also, if I burn firmware without selecting startup, it will not even connect to UIFlow 2.0.
                                            I would really appreciate any guidance you could give.
