    CoreMP135 by UIFlow
    Cores
    5
    9
    4.8k
      MCU1536
      I tried to write the code and download to CoreMP135 by UIFlow 2.2.4.
      I pressed Download the program to device button.
      And connected the serial port.
      The WebTerminal dialog box appeared and shown login message.
      And then I pressed Download the program to device button on WebTerminal dialog box.
      The Progress status shown and then it was stuck.
      Could you suggest me to solve this issue?
      • kurikoK
        kuriko @MCU1536
        @MCU1536
        what will happen if you click run instead of download?
          MCU1536 @kuriko
          @kuriko
          When I clicked the Run button.
          The WebTerminal dialog box appeared and shown "Connected to Serial Port!" message.
          • I pressed Download the program to device button on WebTerminal dialog box.
          • I pressed Run button on WebTerminal dialog box.
            It returned
          ^C
          ^C
          ^C
          ^C
          • kurikoK
            kuriko @MCU1536
            @MCU1536
            we will add a UiFlow2 tutorial for CoreMP135 soon
            • robskiR
              robski @kuriko
              @kuriko which image is the one CoreMP135 is shipped with?
                ajb2k3 @robski
                @robski
                I’m also working on a tutorial as I had issue with the documentation but did get hello world to display.
                I’m using the stock and mage but I have run the updates and changed a few things.
                • robskiR
                  robski @ajb2k3
                  @ajb2k3 said in CoreMP135 by UIFlow:
                  @robski
                  I have sd card which it came with,
                  I've burned spare sd cards with each of available images from M5Stack
                  M5_CoreMP135_buildroot_20240628 and M5_CoreMP135_debian12_20240919
                  but both are only displaying coremp135 logo, where original sd card has some screen test pages
                    ajb2k3 @robski
                    @robski I’m using the Debian image. Did you configure the UIFlow service to auto load on restart?
                    • T
                      Thetom3kK
                      I have exactly the same issue with the coremp135. Any solutions meanwhile?
                      I'd like to use it connected via USB Serial and also upload programs, but now way.
                      BR Tomekk
