    Error!!!!????
    General
    5.6k
      ajb2k3 @Nooblearns
      @Nooblearns what error?
      N 2 Replies Last reply Reply Quote 0
      • N
        Nooblearns @ajb2k3
        @ajb2k3 I was trying to burn UI flow to the M5 stick. What I'm reading is I need CH340 or CP210x? My brother a Dev, is gonna stop by tomorrow and try and help.
        I appreciate the reply.
        • N
          Nooblearns @ajb2k3
          @ajb2k3 ERROR: Command not found at ''
            ajb2k3 @Nooblearns
            @Nooblearns have you installed the ESPtools?
            • robskiR
              robski
              so you downloaded M5Burner correct? and it opens ok?
              what exact model of M5Stick you have - you need to choose correct firmware version.
              is your M5Stick com port detected in M5Burner when usb is plugged in to M5Stick?
              • N
                Nooblearns @robski
                @robski Yes i downloaded M5 burner and Bruce. I have the M5 stick C plus
                • N
                  Nooblearns @ajb2k3
                  @ajb2k3 Esp tools I never downloaded.
                  • N
                    Nooblearns @robski
                    @robski I downloaded M5 burner. I have bin, packages, and m5 burner. It's telling me to extract all files, I did that.
                    When I try and follow along with a video on this, my files don't look the same as in the videoIMG_4571 (1).jpg
                    N robskiR 2 Replies Last reply Reply Quote 0
                    • N
                      Nooblearns @Nooblearns
                      @Nooblearns I really appreciate your time and help!!
                      • robskiR
                        robski @Nooblearns
                        @Nooblearns just unzip in to folder before you run M5Burner
                        • N
                          Nooblearns @robski
                          @robski I deleted M5 burner and I am going to start again. Each time i extracted, nothing happened.
                          • N
                            @Nooblearns Let's goo, I think I am getting somewhere, thanks to you peeps!!!
                            • robskiR
                              robski @Nooblearns
                              @Nooblearns not a good start if M5Burner doesnt play game before you even connect your M5Stick
