    UiFlow 2.0
    74
    188
    422.8k
    • C
      Calilov330000
      Does anyone know how to connect my m5stack core 2 ?
      Im using the raspberry pi 5. Is the m5stackbcore 2 plug and play with raspberry pi or the websites? Ive neen trying to connect this thing for 2 weeks. This is crazy it takes this much trouble
      • kurikoK
        kuriko @Calilov330000
        @Calilov330000
        why don't you try a simple laptop/desktop?
        • D
          Davidalan5757
          Could you unlock from UIFlow 2 the capability to code in micropython…
          • J
            jpilarski
            I am looking for all of the lcd drawing tools that were available in uiflow1.0. I was making some interactive graphics and I was drawing lines or rectangles in a loop and doing that in uiflow2.0 requires you to first drag out 100 lines in the ui builder which just is too slow. Here are the bloacks I am looking for in uiflow 2.0. How can I do something similar in uiflow 2.0 Screenshot 2025-02-18 235307.png
            • C
              charlesRD
              I have some difficulties to burn UIFLOW on new devices
              For ATom lite it seems to work but i get ERROR The device type is unknown! on device manager.
              I dont know if it can acces to the wifi. i tried several time to unregister and burn it again, reinstall M5 burner, but it doesn't help.
              It can't connect to my M5 stamp C3, maybe there is a way to make a factory reset on them?
              The previous Atom and Stick set up in february still worked well, and appears with green dot on device manager. when i try to burn it now i get the "unknown type" error and red dot.
              it looks like i am not able anymore to have the same atom running when i burn them today.
              Did i forgot something ?
              Thank you very much,
              Charles
              • Y
                yaleman
                  sgu @charlesRD
                  @charlesRD
                  i have similar issues
                  the Tab5 does not burn UIFlow at all!
                    sgu
                    When Will LVGL be integrated in UIFlow 2 ? I don't see a progress there for many months. The new devices such as Tab5 are useless without LVGL. Programming with UiFlow 2.0 and printing simple lines and squares look very old school.
                    • H
                      hacxx Banned
                      Thanks for sharing the UiFlow 2.0 resources! I appreciate having a dedicated space for bugs, how-tos, and feature requests. Does anyone have tips on avoiding common firmware burning errors, especially with account binding? Also curious if there’s a timeline for the full API docs release. Looking forward to seeing how this evolves!
                      • T
                        thecuri
                        I recently los all my private cloud projects....is there a way to get them back from your servers?
                        • Z
                          zhumingqi
                          I used UIFlow2 to devleop a simple UI demo, and I monitor the free memory with gc.mem_free(). I found the free memory reduced continiously though I called gc.collect() every loop. Finally, the UI can not update again, but the loop still was running.
                          Z 1 Reply Last reply Reply Quote 0
                          • Z
                            zhumingqi @zhumingqi
                            I tested more UI design. And I found that the memory leak only happens when I use image component and switch images frequently. Is that a UIFlow2.3.3 bug or my design is incorrect?
                            • Z
                              zhumingqi
                              Today, I updated the UIFlow to V2.3.4, and burned V2.3.4 firmware as well. Then I tested that image component again with M5GFX in UIFlow 2.3.4. But the issue still exists. After I switch two JPG pics with one image component for sometime, the memory will reduced continiously. Finally, the system will break out. And I try to use gc.collect() after every drawImage(), but it's not useful.
                              Here is my design and python code:
                              import os, sys, io, gc
                              import M5
                              from M5 import *
                              ImageSwitchFlag = None
                              def GcCollectAndPrint():
                              global ImageSwitchFlag
                              gc.collect()
                              print(gc.mem_free())
                              pass
                              def btnA_wasClicked_event(state):
                              if ImageSwitchFlag == 0:
                              M5.Lcd.drawImage("/flash/res/img/RotaryBGBacklight.jpg", 0, 0)
                              GcCollectAndPrint()
                              ImageSwitchFlag = 1
                              elif ImageSwitchFlag == 1:
                              M5.Lcd.drawImage("/flash/res/img/RotaryBGBT.jpg", 0, 0)
                              GcCollectAndPrint()
                              ImageSwitchFlag = 0
                              def setup():
                              M5.begin()
                              Widgets.fillScreen(0x000000)
                              BtnA.setCallback(type=BtnA.CB_TYPE.WAS_CLICKED, cb=btnA_wasClicked_event)
                              ImageSwitchFlag = 0
                              def loop():
                              M5.update()
                              if name == 'main':
                              try:
                              setup()
                              while True:
                              loop()
                              try:
                              print_error_msg(e)
                              except ImportError:
                              print("please update to latest firmware")******
                                Schwibach
                                I wrote in another thread about my Sync... 0% problem.
                                I am pretty sure now that it is a bug. I does not matter which program I use. I can run them from UIFlow 2.0. But as soon as I download a program, I will get the Sync... 0%
                                Also, if I burn firmware without selecting startup, it will not even connect to UIFlow 2.0.
                                I would really appreciate any guidance you could give.
                                • O
                                  otosan-maker
                                  I have found a bug in MQTT software. When I subscrive to a topic, the python code creates the subscription at the beggining of the setup code, before it connects to wifi and mqtt.
                                  Here is the sample:
                                  def setup():
                                  global page0, label0, LTemp, label1, temperatura, slider0, button0, off, mqtt_client, wlan, rotary
                                  mqtt_client.subscribe('termostato/temperatura', mqtt_termostato_temperatura_event, qos=0)
                                  M5.begin()
                                  m5ui.init()
                                  page0 = m5ui.M5Page(bg_c=0xffffff)
                                  label0 = m5ui.M5Label("Umbral", x=30, y=81, text_c=0x85231b, bg_c=0x302c2c, bg_opa=0, font=lv.font_montserrat_24, parent=page0)
                                  LTemp = m5ui.M5Label("Temperatura:", x=41, y=39, text_c=0x000000, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_14, parent=page0)
                                  label1 = m5ui.M5Label("19,0", x=152, y=81, text_c=0x85231b, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_24, parent=page0)
                                  temperatura = m5ui.M5Label("00.00", x=141, y=39, text_c=0x000000, bg_c=0xffffff, bg_opa=0, font=lv.font_montserrat_14, parent=page0)
                                  slider0 = m5ui.M5Slider(x=38, y=119, w=160, h=22, mode=lv.slider.MODE.NORMAL, min_value=190, max_value=290, value=210, bg_c=0x115e9f, color=0x2c90e4, parent=page0)
                                  button0 = m5ui.M5Button(text="Set", x=54, y=172, bg_c=0x2196f3, text_c=0xffffff, font=lv.font_montserrat_14, parent=page0)
                                  off = m5ui.M5Button(text="OFF", x=124, y=171, bg_c=0xf36021, text_c=0xffffff, font=lv.font_montserrat_14, parent=page0)
                                  off.add_event_cb(off_event_handler, lv.EVENT.ALL, None)
                                  slider0.add_event_cb(slider0_event_handler, lv.EVENT.ALL, None)
                                  button0.add_event_cb(button0_event_handler, lv.EVENT.ALL, None)
                                  page0.screen_load()
                                  wlan = network.WLAN(network.STA_IF)
                                  rotary = Rotary()
                                  wlan.connect('bencab', 'arrabal6')
                                  rotary.set_rotary_value(19)
                                  mqtt_client = MQTTClient('m5termostato', '192.168.1.34', port=1883, user='user', password='pass', keepalive=33149)
                                  label1.set_text(str((slider0.get_value()) / 10))
                                  • O
                                    otosan-maker
