    TAB5 and Uniflow2.0
    UiFlow 2.0
    846
    • H
      Handcannon
      Got the Tab5 last week and been doing different Uiflow2.0 sensors and Lights etc. Just playing with it.
      Problem is that all of the Programs with just sensors and no buttons work great. Can reset back to menu and load from device. Anything with buttons locks up the Tab5 after loaded and configured from M5Burner after download. Core2 and Core3 all run find with the updated firmware. Any ideas???
      • kurikoK
        kuriko
        @Handcannon
        hmmm not very sure what your problem is... are you able to provide some photo or videos?
        • H
          Handcannon
          I have some programs that I made in Uniflow2.0 for the Tab5. M5UI programs for sensors etc. work great load and run perfect. When I reset it goes back to the Uniflow2.0 menu just like it is supposed to.
          M5GFX I make the program using Uniflow2.0 and run and test all works great. Then I down load the program. I then reconfigure it in M5Burner and it goes back to menu. If I run a M5UI program all is good. But when I try to run the M5GFX it locks up the Tab5. I reset and it will go back to Uniflow2.0 start up screen like it should. And will run and reset all M5UI apps perfect. When I try M5GFX app it locks it up again.
          I have deleted the program and reinstalled the new version a few time and same results.
          Any app that has a used the M5GFX will work great when testing but then after downloading will lock up the Tab5
          • H
            Handcannon
            uiflow2_block_1756296466368.png This is one of them that will run great when testing. But after down load will lock up device when I try to run it. Side note. The light will flash at first like it is tryi ng to work.
            • H
              Handcannon
              I am sorry but I have the interface backwards. The M5UI interface with the buttons etc. is the one that locks up. Not the M5GFX. Sorry for the screw up.
