@watson
Yes, but is only the StickC that is giving the strange port ID.
All others report normal port.
@gachapo I means you can modify main.c file if you want to access other ip address during wifi setting instead of
192.168.4.1
. Then compile the camera firmware again and burn it to ESP32CAM
I understood this problem.
We need to fix M5Burner for mac.
@salty_good said in [updated for Camera boards] M5 Burner Firmware Option Update:
Can you add drop down box to select port?
ポートを選択するためのドロップダウンボックスを追加できますか?
@ajb2k3 Off course yes,
and Baudrate also needs to be selectable.
@watson Thanks - I have amended this. Am I best to use Arduino IDE to compile and upload? Currently when I use Arduino I have several error messages.
Hello @gachapo It's best to use esp-idf.
@watson Thanks- can you use arduino-ide?
@watson Thank you.
Do I choose CAMERA_MODEL_WROVER_KIT?
You need chang this source code about camera hardware configuration for adapting to ESP32CAM. Because the arduino source code is for M5Camera A model.
// Select camera model //#define CAMERA_MODEL_WROVER_KIT #define CAMERA_A_MODEL_M5STACK_PSRAM //#define CAMERA_MODEL_AI_THINKER
@watson I have downloaded the M5CamColourRecognition.ino and uploaded to camera successfully. I now have an issued IP address to my network, which I have browsed to and the software loads. However, when I either click get picture or start stream it doesn't work. Please advise?
@gachapo Do you modify those pin map for adapting to ESP32CAM not M5Camera (A model)?
https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L62#elif defined(CAMERA_A_MODEL_M5STACK_PSRAM) #define PWDN_GPIO_NUM -1 #define RESET_GPIO_NUM 15 #define XCLK_GPIO_NUM 27 #define SIOD_GPIO_NUM 25 #define SIOC_GPIO_NUM 23 #define Y9_GPIO_NUM 19 #define Y8_GPIO_NUM 36 #define Y7_GPIO_NUM 18 #define Y6_GPIO_NUM 39 #define Y5_GPIO_NUM 5 #define Y4_GPIO_NUM 34 #define Y3_GPIO_NUM 35 #define Y2_GPIO_NUM 32 #define VSYNC_GPIO_NUM 22 #define HREF_GPIO_NUM 26 #define PCLK_GPIO_NUM 21
Yes, as far as I'm aware as long as I have chosen the correct (or in this case closest match) at the top the defined pins should be loaded as below;
Hello - I've downloaded before but I don't think it has .ino files so can't be used with Arduino.ide. Please advise?
@gachapo said in [Solved] M5 Burner Firmware Option Update:
No, the driver is compiled with the espressiv IDF and so you need to install that and configure it to compile.
Something I have failed to do several times now.
can also program with arduino ide
