    Purchased a m5StickV - Fixed in recent firmware update.
    PRODUCTS
    25
    83.3k
      ajb2k3 @Xeon
      @xeon said in Purchased a m5StickV:
      Holding the power button 6 seconds to try turn it off.
      It keeps powering back on right away.
      1. for the love of all that is holy.
        Tell people that sell your device the mic is broken and your looking to dump the project and your losses on it.
      2. if you make a basic firmware, make sure the off button actually does what the manual says.
      3. the manual covers less than some terrible products.
      4. i can't even understand it's quirks.. connecting via serial reboots it??
        Then serial monitor is lost searching.
      Starting to think i made a huge mistake.
      such a awesome device.. so much potential.
      :edit
      reflashed stock.
      still can't turn it off.
      am i missing a trick?
      How did you reflash it, what firmware did you use?
      BTW the microphone issue only came up after the release and there was an announcement about the issue
      • X
        Xeon
        i used kflash_gui V1.5.3
        used the latest firmware.
        http://dl.sipeed.com/MAIX/MaixPy/release/master/maixpy_v0.4.0_52_g3b8c18b
        do i need a script present ?
        The war of 1 and 0 draws ever closer.
        everyday i work to become a cyborg.
        • X
          Xeon @Xeon
          Ahh Sorry.. idk what happened.
          i apologize if i seem aggressive the device was acting very odd.
          i purged my serial drivers and reflashed
          Seems to be working as i hoped.
          ty for not banning me.
            ajb2k3 @Xeon
            @xeon No worries, I've been having issues aswell but reflashing does help
            • X
              Xeon @ajb2k3
              the problem came back.
              i don't know how.
                ajb2k3 @Xeon
                i don't know how.
                After a reflash the issue is back?
                Please email the M5Stack support people. something is defiantly not correct.
                • X
                  Xeon @ajb2k3
                  i found a few work arounds.
                  1. Cant turn off
                    Letting the battery run out seems to solve the power button.
                    As it works fine again afterward.
                  2. Keeps bugging out after running a script in Maix Py ide
                    Disconnect a reconnect
                  • X
                    Xeon
                    device begins doing this when fully charged.
                    • F
                      FPSychotic
                      Same issues here
                      • X
                        Xeon @FPSychotic
                        @fpsychotic
                        Did yours get very hot while charging?
                          ajb2k3 @Xeon
                          @fpsychotic
                          Yes, mine does get hot
                          BTW there is already a MK2 on its way.
                          • T
                            Thrasher
                            Mine cant last long with battery.. I left it to charge for couple of hours and after that it worked maybe 2 minutes.. I keep it plugged into powerbank
                            • F
                              FPSychotic @ajb2k3
                              Not really and it last some time with battery.
                              v2? the wifi one? if is not wifi, what is the difference and were you got?
                                ajb2k3 @FPSychotic
                                @fpsychotic I've got the MK1 as the MKII isn't out yet
                                • X
                                  Xeon
                                  i verified it.
                                  after reaching 70 to 90% full battery the device wont power off.
                                  it just reboots.
                                  after going below this threshold it turns off again normally.
                                  • T
                                    Thrasher
                                    Hardmode it with dc-dc stepdown to keep battery outcome always below 70% :))
                                    • X
                                      Xeon
                                      Well my battery is now rotten thanks to this.
                                      The battery life is fading very fast.
                                      I want a replacement.
                                      i bought this device to get a task done.
                                      it's going to.
                                        ajb2k3 @Xeon
                                        @xeon have you contacted M5Stack support about this? They should be available now
                                        • X
                                          Xeon @ajb2k3
                                          @ajb2k3 said in Purchased a m5StickV:
                                          They verified the problem and will release a fix soon.
                                            ajb2k3 @Xeon
                                            Glad to hear it.
