    Purchased a m5StickV - Fixed in recent firmware update.
    PRODUCTS
    25
    83.3k
    • X
      Xeon @ajb2k3
      i found a few work arounds.
      1. Cant turn off
        Letting the battery run out seems to solve the power button.
        As it works fine again afterward.
      2. Keeps bugging out after running a script in Maix Py ide
        Disconnect a reconnect
      The war of 1 and 0 draws ever closer.
      everyday i work to become a cyborg.
      • X
        Xeon
        device begins doing this when fully charged.
        • F
          FPSychotic
          Same issues here
          • X
            Xeon @FPSychotic
            @fpsychotic
            Did yours get very hot while charging?
              ajb2k3 @Xeon
              @xeon said in Purchased a m5StickV:
              @fpsychotic
              Yes, mine does get hot
              BTW there is already a MK2 on its way.
              • T
                Thrasher
                Mine cant last long with battery.. I left it to charge for couple of hours and after that it worked maybe 2 minutes.. I keep it plugged into powerbank
                • F
                  FPSychotic @ajb2k3
                  Not really and it last some time with battery.
                  v2? the wifi one? if is not wifi, what is the difference and were you got?
                    ajb2k3 @FPSychotic
                    @fpsychotic I've got the MK1 as the MKII isn't out yet
                    • X
                      Xeon
                      i verified it.
                      after reaching 70 to 90% full battery the device wont power off.
                      it just reboots.
                      after going below this threshold it turns off again normally.
                      • T
                        Thrasher
                        Hardmode it with dc-dc stepdown to keep battery outcome always below 70% :))
                        • X
                          Xeon
                          Well my battery is now rotten thanks to this.
                          The battery life is fading very fast.
                          I want a replacement.
                          i bought this device to get a task done.
                          it's going to.
                            ajb2k3 @Xeon
                            @xeon have you contacted M5Stack support about this? They should be available now
                            • X
                              Xeon @ajb2k3
                              @ajb2k3 said in Purchased a m5StickV:
                              They verified the problem and will release a fix soon.
                                ajb2k3 @Xeon
                                Glad to hear it.
                                • X
                                  Xeon @ajb2k3
                                  @ajb2k3 So far i managed to program a demo with all the source lying around thanks to our great friends here sharing.
                                  But there are a few source examples i'm looking for.
                                  i'm trying to make a program that tests as many functions and features as possible.
                                  import audio
                                  import gc
                                  import image
                                  import lcd
                                  import sensor
                                  import sys
                                  import time
                                  import utime
                                  import uos
                                  import _thread
                                  import pmu
                                  import KPU as kpu
                                  from fpioa_manager import *
                                  from machine import I2C
                                  from Maix import I2S, GPIO
                                  time.sleep(2)
                                  Initialize
                                  Lcd setup
                                  lcd.init()
                                  lcd.rotation(2)
                                  i2c = I2C(I2C.I2C0, freq=400000, scl=28, sda=29)
                                  Speaker setup
                                  fm.register(board_info.SPK_SD, fm.fpioa.GPIO0)
                                  spk_sd=GPIO(GPIO.GPIO0, GPIO.OUT)
                                  spk_sd.value(1) #Enable the SPK output
                                  fm.register(board_info.SPK_DIN,fm.fpioa.I2S0_OUT_D1)
                                  fm.register(board_info.SPK_BCLK,fm.fpioa.I2S0_SCLK)
                                  fm.register(board_info.SPK_LRCLK,fm.fpioa.I2S0_WS)
                                  wav_dev = I2S(I2S.DEVICE_0)
                                  Init battery monitor axp192
                                  axp = pmu.axp192()
                                  axp.enableADCs(True)
                                  Setup A and B buttons
                                  fm.register(board_info.BUTTON_A, fm.fpioa.GPIO1)
                                  but_a=GPIO(GPIO.GPIO1, GPIO.IN, GPIO.PULL_UP) #PULL_UP is required here!
                                  fm.register(board_info.BUTTON_B, fm.fpioa.GPIO2)
                                  but_b = GPIO(GPIO.GPIO2, GPIO.IN, GPIO.PULL_UP) #PULL_UP is required here!
                                  but_a_pressed = 0
                                  but_b_pressed = 0
                                  but_stu = 1
                                  cnt_f = 0
                                  Setup LED's
                                  fm.register(board_info.LED_W, fm.fpioa.GPIO3)
                                  led_w = GPIO(GPIO.GPIO3, GPIO.OUT) #RGBW "White" LED
                                  led_w.value(1) #RGBW "White" LED is Active Low
                                  fm.register(board_info.LED_R, fm.fpioa.GPIO4)
                                  led_r = GPIO(GPIO.GPIO4, GPIO.OUT) #RGBW "Red" LED
                                  led_r.value(1) #RGBW "Red" LED is Active Low
                                  fm.register(board_info.LED_G, fm.fpioa.GPIO5)
                                  led_g = GPIO(GPIO.GPIO5, GPIO.OUT) #RGBW "Green" LED
                                  led_g.value(1) #RGBW "Green" LED is Active Low
                                  fm.register(board_info.LED_B, fm.fpioa.GPIO6)
                                  led_b = GPIO(GPIO.GPIO6, GPIO.OUT) #RGBW "Blue" LED
                                  led_b.value(1) #RGBW #RGBW "Blue" LED is Active Low
                                  Define image filters
                                  origin = (0,0,0, 0,1,0, 0,0,0)
                                  edge = (-1,-1,-1,-1,8,-1,-1,-1,-1)
                                  sharp = (-1,-1,-1,-1,9,-1,-1,-1,-1)
                                  relievo = (2,0,0,0,-1,0,0,0,-1)
                                  Subs
                                  def fade_scrn(fspd,dirr): # Use backlight to fade screen dirr = dirrection 0 = in 1 = out
                                  for i in range(9):
                                  if dirr == 0:
                                  set_backlight(i)
                                  if dirr == 1:
                                  ti = 9 - i
                                  set_backlight(ti)
                                  time.sleep(fspd)
                                  def play_sound(filename,vol):
                                  try:
                                  player = audio.Audio(path = filename)
                                  player.volume(vol)
                                  wav_info = player.play_process(wav_dev)
                                  wav_dev.channel_config(wav_dev.CHANNEL_1, I2S.TRANSMITTER,resolution = I2S.RESOLUTION_16_BIT, align_mode = I2S.STANDARD_MODE)
                                  wav_dev.set_sample_rate(wav_info[1])
                                  while True:
                                  ret = player.play()
                                  if ret == None:
                                  break
                                  elif ret==0:
                                  break
                                  player.finish()
                                  except:
                                  pass
                                  def set_backlight(level): # Set backlight brightness ranges from 0 to 8
                                  if level > 8:
                                  level = 8
                                  if level < 0:
                                  level = 0
                                  val = (level+7) << 4
                                  i2c.writeto_mem(0x34, 0x91,int(val))
                                  def show_logo():
                                  led_r.value(0)
                                  img = image.Image("/sd/startup1.jpg")
                                  time.sleep(0.15)
                                  led_r.value(1)
                                  set_backlight(0)
                                  lcd.display(img)
                                  fade_scrn(0.02,0)
                                  led_w.value(0)
                                  led_b.value(0)
                                  play_sound("/sd/logo.wav",70)
                                  led_b.value(1)
                                  fade_scrn(0.02,1)
                                  img = image.Image("/sd/startup2.jpg")
                                  lcd.display(img)
                                  fade_scrn(0.02,0)
                                  play_sound("/sd/ding1.wav",70)
                                  time.sleep(2)
                                  led_w.value(1)
                                  def init_camera(): #initialize sensor
                                  led_b.value(0)
                                  led_r.value(0)
                                  err_counter = 0
                                  while 1:
                                  try:
                                  sensor.reset() # Reset sensor.
                                  break
                                  except:
                                  err_counter = err_counter + 1
                                  if err_counter == 20:
                                  led_r.value(0) # Led stays red if sensor failed to initialize.
                                  lcd.draw_string(lcd.width()//2-100,lcd.height()//2-4, "Error: Sensor Init Failed", lcd.WHITE, lcd.RED)
                                  time.sleep(0.1)
                                  continue
                                  led_b.value(1)
                                  led_r.value(1)
                                  led_g.value(0) # Led turns Green meaning all good.
                                  play_sound("/sd/ding2.wav",70)
                                  sensor.set_pixformat(sensor.RGB565)
                                  sensor.set_framesize(sensor.QVGA) #QVGA=320x240
                                  sensor.run(1)
                                  time.sleep(0.5)
                                  led_g.value(1)
                                  def show_batt_stats():
                                  val = axp.getVbatVoltage()
                                  img.draw_string(52, 60, "Bat V:" + str(val), color=(230,0,0))
                                  val = axp.getBatteryDischargeCurrent()
                                  img.draw_string(52, 72, "Bat I:" + str(val), color=(230,0,0))
                                  val = axp.getUSBVoltage()
                                  img.draw_string(52, 84, "USB V:" + str(val), color=(230,0,0))
                                  val = axp.getUSBInputCurrent()
                                  img.draw_string(52, 96, "USB I:" + str(val), color=(230,0,0))
                                  val = axp.getBatteryInstantWatts()
                                  img.draw_string(52, 108, "I W:" + str(val), color=(230,0,0))
                                  val = axp.getTemperature()
                                  img.draw_string(52, 120, "Temp*:" + str(val), color=(230,0,0))
                                  def apply_filter(cnt_f):
                                  if cnt_f==1: #cycle filters 1=edge, 2=sharp, 3=relievo, 4=origin, 0 = skip filter
                                  img.conv3(edge)
                                  img.draw_string(52,60, "edge",color=(255,0,0))
                                  elif cnt_f==2:
                                  img.conv3(sharp)
                                  img.draw_string(52,60, "sharp",color=(255,0,0))
                                  elif cnt_f==3:
                                  img.conv3(relievo)
                                  img.draw_string(52,60, "relievo",color=(255,0,0))
                                  elif cnt_f==4:
                                  img.conv3(origin) #reset filter
                                  img.draw_string(52,60, "origin",color=(255,0,0))
                                  else :
                                  cnt_f=0
                                  Main
                                  show_logo()
                                  if but_a.value() == 0: #If dont want to run the demo
                                  img = image.Image("/sd/startup3.jpg")
                                  lcd.display(img)
                                  print('[info]: Exit by user operation')
                                  fade_scrn(0.02,1)
                                  time.sleep(0.02)
                                  set_backlight(0)
                                  sys.exit()
                                  init_camera()
                                  Define list of classes
                                  classes = ['aeroplane', 'bicycle', 'bird', 'boat', 'bottle', 'bus', 'car', 'cat', 'chair', 'cow', 'diningtable', 'dog', 'horse', 'motorbike', 'person', 'pottedplant', 'sheep', 'sofa', 'train', 'tvmonitor']
                                  task = kpu.load("/sd/model/20class.kmodel")
                                  task_face = kpu.load(0x300000) # default face detection model on flash memory
                                  task_face = kpu.load("/sd/model/facedetect.kmodel") # you can extract the model from default .kfpkg
                                  anchor = (1.889, 2.5245, 2.9465, 3.94056, 3.99987, 5.3658, 5.155437, 6.92275, 6.718375, 9.01025)
                                  Anchor data is for bbox, extracted from the training sets.
                                  kpu.init_yolo2(task, 0.5, 0.3, 5, anchor)
                                  kpu.init_yolo2(task_face, 0.5, 0.3, 5, anchor)
                                  print('[info]: Started.')
                                  fade_scrn(0.02,1)
                                  img = sensor.snapshot()
                                  lcd.display(img)
                                  fade_scrn(0.02,0)
                                  led_g.value(1)
                                  green_threshold = (0, 80, -70, -10, -0, 30)
                                  try:
                                  while(True):
                                      img=sensor.snapshot() # Take Snapshot
                                      # Press B and A to cycle thru filters
                                      if but_b.value() == 0 and but_a.value() == 0 and but_b_pressed == 0:
                                          cnt_f=cnt_f+1
                                          but_b_pressed=1
                                          #play_sound("/sd/ding2.wav",70)
                                      if but_b.value() == 1 and but_a.value() == 0 and but_b_pressed == 1:
                                          but_b_pressed=0
                                      if cnt_f==5:
                                          cnt_f=0
                                      apply_filter(cnt_f)
                                      gc.collect()
                                      code_obj = kpu.run_yolo2(task, img)
                                      code_face = kpu.run_yolo2(task_face, img)
                                      if code_obj: # object detected
                                          max_id = 0
                                          max_rect = 0
                                          for i in code_obj:
                                              img.draw_rectangle(i.rect())
                                              text = ' ' + classes[i.classid()] + ' (' + str(int(i.value()*100)) + '%) '
                                              for x in range(-1,2):
                                                  for y in range(-1,2):
                                                      img.draw_string(x+i.x(), y+i.y()+(i.h()>>1), text, color=(255,255,255), scale=1.5,mono_space=False)
                                              img.draw_string(i.x(), i.y()+(i.h()>>1), text, color=(255,25,25), scale=1.5,mono_space=False) #display detected object name
                                              id = i.classid()
                                              rect_size = i.w() * i.h()
                                              if rect_size > max_rect:
                                                  max_rect = rect_size
                                                  max_id = id
                                          if but_a.value() == 0 and but_b.value() == 1:
                                              led_w.value(0)
                                              play_sound("/sd/voice/en/"+str(max_id)+".wav",70)
                                              led_w.value(1)
                                      if code_face: # face detected
                                          max_id = 0
                                          max_rect = 0
                                          for i in code_face:
                                              img.draw_rectangle(i.rect(),color=(230,0,0))
                                      if but_b.value() == 0 and but_a.value() == 1: # press B for battery stats overlay
                                          show_batt_stats()
                                      #gc.collect()
                                      #blobs = img.find_blobs([green_threshold])
                                      #if blobs:
                                          #for b in blobs:
                                              #tmp=img.draw_rectangle(b[0:4])
                                              #tmp=img.draw_cross(b[5], b[6])
                                              #c=img.get_pixel(b[5], b[6])
                                      lcd.display(img)
                                  except KeyboardInterrupt:
                                  kpu.deinit(task)
                                  kpu.deinit(task_face)
                                  sys.exit()
                                  • T
                                    Thrasher
                                    Xeon, I've noticed pretty same problem on my stick-v today.
                                    Whenever I press and hold turn-off button stick reboots instead of turning off.
                                    In my case this happens whenever SD card is plugged in. I've removed it and everything works as intended now
                                    • X
                                      Xeon @Thrasher
                                      @thrasher
                                      latest Firmware fixes this.
                                      http://forum.m5stack.com/topic/1403/m5stickv-firmware_1017-upgrade
