    Purchased a m5StickV - Fixed in recent firmware update.
    PRODUCTS
    25
    88.5k
    • F
      FPSychotic @ajb2k3
      Not really and it last some time with battery.
      v2? the wifi one? if is not wifi, what is the difference and were you got?
        ajb2k3 @FPSychotic
        @fpsychotic I've got the MK1 as the MKII isn't out yet
        • X
          Xeon
          i verified it.
          after reaching 70 to 90% full battery the device wont power off.
          it just reboots.
          after going below this threshold it turns off again normally.
          The war of 1 and 0 draws ever closer.
          everyday i work to become a cyborg.
          • T
            Thrasher
            Hardmode it with dc-dc stepdown to keep battery outcome always below 70% :))
            • X
              Xeon
              Well my battery is now rotten thanks to this.
              The battery life is fading very fast.
              I want a replacement.
              i bought this device to get a task done.
              it's going to.
                ajb2k3 @Xeon
                @xeon have you contacted M5Stack support about this? They should be available now
                • X
                  Xeon @ajb2k3
                  @ajb2k3 said in Purchased a m5StickV:
                  They verified the problem and will release a fix soon.
                    ajb2k3 @Xeon
                    @xeon said in Purchased a m5StickV:
                    Glad to hear it.
                    • X
                      Xeon @ajb2k3
                      @ajb2k3 So far i managed to program a demo with all the source lying around thanks to our great friends here sharing.
                      But there are a few source examples i'm looking for.
                      i'm trying to make a program that tests as many functions and features as possible.
                      import audio
                      import gc
                      import image
                      import lcd
                      import sensor
                      import sys
                      import time
                      import utime
                      import uos
                      import _thread
                      import pmu
                      import KPU as kpu
                      from fpioa_manager import *
                      from machine import I2C
                      from Maix import I2S, GPIO
                      time.sleep(2)
                      Initialize
                      Lcd setup
                      lcd.init()
                      lcd.rotation(2)
                      i2c = I2C(I2C.I2C0, freq=400000, scl=28, sda=29)
                      Speaker setup
                      fm.register(board_info.SPK_SD, fm.fpioa.GPIO0)
                      spk_sd=GPIO(GPIO.GPIO0, GPIO.OUT)
                      spk_sd.value(1) #Enable the SPK output
                      fm.register(board_info.SPK_DIN,fm.fpioa.I2S0_OUT_D1)
                      fm.register(board_info.SPK_BCLK,fm.fpioa.I2S0_SCLK)
                      fm.register(board_info.SPK_LRCLK,fm.fpioa.I2S0_WS)
                      wav_dev = I2S(I2S.DEVICE_0)
                      Init battery monitor axp192
                      axp = pmu.axp192()
                      axp.enableADCs(True)
                      Setup A and B buttons
                      fm.register(board_info.BUTTON_A, fm.fpioa.GPIO1)
                      but_a=GPIO(GPIO.GPIO1, GPIO.IN, GPIO.PULL_UP) #PULL_UP is required here!
                      fm.register(board_info.BUTTON_B, fm.fpioa.GPIO2)
                      but_b = GPIO(GPIO.GPIO2, GPIO.IN, GPIO.PULL_UP) #PULL_UP is required here!
                      but_a_pressed = 0
                      but_b_pressed = 0
                      but_stu = 1
                      cnt_f = 0
                      Setup LED's
                      fm.register(board_info.LED_W, fm.fpioa.GPIO3)
                      led_w = GPIO(GPIO.GPIO3, GPIO.OUT) #RGBW "White" LED
                      led_w.value(1) #RGBW "White" LED is Active Low
                      fm.register(board_info.LED_R, fm.fpioa.GPIO4)
                      led_r = GPIO(GPIO.GPIO4, GPIO.OUT) #RGBW "Red" LED
                      led_r.value(1) #RGBW "Red" LED is Active Low
                      fm.register(board_info.LED_G, fm.fpioa.GPIO5)
                      led_g = GPIO(GPIO.GPIO5, GPIO.OUT) #RGBW "Green" LED
                      led_g.value(1) #RGBW "Green" LED is Active Low
                      fm.register(board_info.LED_B, fm.fpioa.GPIO6)
                      led_b = GPIO(GPIO.GPIO6, GPIO.OUT) #RGBW "Blue" LED
                      led_b.value(1) #RGBW #RGBW "Blue" LED is Active Low
                      Define image filters
                      origin = (0,0,0, 0,1,0, 0,0,0)
                      edge = (-1,-1,-1,-1,8,-1,-1,-1,-1)
                      sharp = (-1,-1,-1,-1,9,-1,-1,-1,-1)
                      relievo = (2,0,0,0,-1,0,0,0,-1)
                      Subs
                      def fade_scrn(fspd,dirr): # Use backlight to fade screen dirr = dirrection 0 = in 1 = out
                      for i in range(9):
                      if dirr == 0:
                      set_backlight(i)
                      if dirr == 1:
                      ti = 9 - i
                      set_backlight(ti)
                      time.sleep(fspd)
                      def play_sound(filename,vol):
                      try:
                      player = audio.Audio(path = filename)
                      player.volume(vol)
                      wav_info = player.play_process(wav_dev)
                      wav_dev.channel_config(wav_dev.CHANNEL_1, I2S.TRANSMITTER,resolution = I2S.RESOLUTION_16_BIT, align_mode = I2S.STANDARD_MODE)
                      wav_dev.set_sample_rate(wav_info[1])
                      while True:
                      ret = player.play()
                      if ret == None:
                      break
                      elif ret==0:
                      break
                      player.finish()
                      except:
                      pass
                      def set_backlight(level): # Set backlight brightness ranges from 0 to 8
                      if level > 8:
                      level = 8
                      if level < 0:
                      level = 0
                      val = (level+7) << 4
                      i2c.writeto_mem(0x34, 0x91,int(val))
                      def show_logo():
                      led_r.value(0)
                      img = image.Image("/sd/startup1.jpg")
                      time.sleep(0.15)
                      led_r.value(1)
                      set_backlight(0)
                      lcd.display(img)
                      fade_scrn(0.02,0)
                      led_w.value(0)
                      led_b.value(0)
                      play_sound("/sd/logo.wav",70)
                      led_b.value(1)
                      fade_scrn(0.02,1)
                      img = image.Image("/sd/startup2.jpg")
                      lcd.display(img)
                      fade_scrn(0.02,0)
                      play_sound("/sd/ding1.wav",70)
                      time.sleep(2)
                      led_w.value(1)
                      def init_camera(): #initialize sensor
                      led_b.value(0)
                      led_r.value(0)
                      err_counter = 0
                      while 1:
                      try:
                      sensor.reset() # Reset sensor.
                      break
                      except:
                      err_counter = err_counter + 1
                      if err_counter == 20:
                      led_r.value(0) # Led stays red if sensor failed to initialize.
                      lcd.draw_string(lcd.width()//2-100,lcd.height()//2-4, "Error: Sensor Init Failed", lcd.WHITE, lcd.RED)
                      time.sleep(0.1)
                      continue
                      led_b.value(1)
                      led_r.value(1)
                      led_g.value(0) # Led turns Green meaning all good.
                      play_sound("/sd/ding2.wav",70)
                      sensor.set_pixformat(sensor.RGB565)
                      sensor.set_framesize(sensor.QVGA) #QVGA=320x240
                      sensor.run(1)
                      time.sleep(0.5)
                      led_g.value(1)
                      def show_batt_stats():
                      val = axp.getVbatVoltage()
                      img.draw_string(52, 60, "Bat V:" + str(val), color=(230,0,0))
                      val = axp.getBatteryDischargeCurrent()
                      img.draw_string(52, 72, "Bat I:" + str(val), color=(230,0,0))
                      val = axp.getUSBVoltage()
                      img.draw_string(52, 84, "USB V:" + str(val), color=(230,0,0))
                      val = axp.getUSBInputCurrent()
                      img.draw_string(52, 96, "USB I:" + str(val), color=(230,0,0))
                      val = axp.getBatteryInstantWatts()
                      img.draw_string(52, 108, "I W:" + str(val), color=(230,0,0))
                      val = axp.getTemperature()
                      img.draw_string(52, 120, "Temp*:" + str(val), color=(230,0,0))
                      def apply_filter(cnt_f):
                      if cnt_f==1: #cycle filters 1=edge, 2=sharp, 3=relievo, 4=origin, 0 = skip filter
                      img.conv3(edge)
                      img.draw_string(52,60, "edge",color=(255,0,0))
                      elif cnt_f==2:
                      img.conv3(sharp)
                      img.draw_string(52,60, "sharp",color=(255,0,0))
                      elif cnt_f==3:
                      img.conv3(relievo)
                      img.draw_string(52,60, "relievo",color=(255,0,0))
                      elif cnt_f==4:
                      img.conv3(origin) #reset filter
                      img.draw_string(52,60, "origin",color=(255,0,0))
                      else :
                      cnt_f=0
                      Main
                      show_logo()
                      if but_a.value() == 0: #If dont want to run the demo
                      img = image.Image("/sd/startup3.jpg")
                      lcd.display(img)
                      print('[info]: Exit by user operation')
                      fade_scrn(0.02,1)
                      time.sleep(0.02)
                      set_backlight(0)
                      sys.exit()
                      init_camera()
                      Define list of classes
                      classes = ['aeroplane', 'bicycle', 'bird', 'boat', 'bottle', 'bus', 'car', 'cat', 'chair', 'cow', 'diningtable', 'dog', 'horse', 'motorbike', 'person', 'pottedplant', 'sheep', 'sofa', 'train', 'tvmonitor']
                      task = kpu.load("/sd/model/20class.kmodel")
                      task_face = kpu.load(0x300000) # default face detection model on flash memory
                      task_face = kpu.load("/sd/model/facedetect.kmodel") # you can extract the model from default .kfpkg
                      anchor = (1.889, 2.5245, 2.9465, 3.94056, 3.99987, 5.3658, 5.155437, 6.92275, 6.718375, 9.01025)
                      Anchor data is for bbox, extracted from the training sets.
                      kpu.init_yolo2(task, 0.5, 0.3, 5, anchor)
                      kpu.init_yolo2(task_face, 0.5, 0.3, 5, anchor)
                      print('[info]: Started.')
                      fade_scrn(0.02,1)
                      img = sensor.snapshot()
                      lcd.display(img)
                      fade_scrn(0.02,0)
                      led_g.value(1)
                      green_threshold = (0, 80, -70, -10, -0, 30)
                      try:
                      while(True):
                          img=sensor.snapshot() # Take Snapshot
                          # Press B and A to cycle thru filters
                          if but_b.value() == 0 and but_a.value() == 0 and but_b_pressed == 0:
                              cnt_f=cnt_f+1
                              but_b_pressed=1
                              #play_sound("/sd/ding2.wav",70)
                          if but_b.value() == 1 and but_a.value() == 0 and but_b_pressed == 1:
                              but_b_pressed=0
                          if cnt_f==5:
                              cnt_f=0
                          apply_filter(cnt_f)
                          gc.collect()
                          code_obj = kpu.run_yolo2(task, img)
                          code_face = kpu.run_yolo2(task_face, img)
                          if code_obj: # object detected
                              max_id = 0
                              max_rect = 0
                              for i in code_obj:
                                  img.draw_rectangle(i.rect())
                                  text = ' ' + classes[i.classid()] + ' (' + str(int(i.value()*100)) + '%) '
                                  for x in range(-1,2):
                                      for y in range(-1,2):
                                          img.draw_string(x+i.x(), y+i.y()+(i.h()>>1), text, color=(255,255,255), scale=1.5,mono_space=False)
                                  img.draw_string(i.x(), i.y()+(i.h()>>1), text, color=(255,25,25), scale=1.5,mono_space=False) #display detected object name
                                  id = i.classid()
                                  rect_size = i.w() * i.h()
                                  if rect_size > max_rect:
                                      max_rect = rect_size
                                      max_id = id
                              if but_a.value() == 0 and but_b.value() == 1:
                                  led_w.value(0)
                                  play_sound("/sd/voice/en/"+str(max_id)+".wav",70)
                                  led_w.value(1)
                          if code_face: # face detected
                              max_id = 0
                              max_rect = 0
                              for i in code_face:
                                  img.draw_rectangle(i.rect(),color=(230,0,0))
                          if but_b.value() == 0 and but_a.value() == 1: # press B for battery stats overlay
                              show_batt_stats()
                          #gc.collect()
                          #blobs = img.find_blobs([green_threshold])
                          #if blobs:
                              #for b in blobs:
                                  #tmp=img.draw_rectangle(b[0:4])
                                  #tmp=img.draw_cross(b[5], b[6])
                                  #c=img.get_pixel(b[5], b[6])
                          lcd.display(img)
                      except KeyboardInterrupt:
                      kpu.deinit(task)
                      kpu.deinit(task_face)
                      sys.exit()
                      • T
                        Thrasher
                        Xeon, I've noticed pretty same problem on my stick-v today.
                        Whenever I press and hold turn-off button stick reboots instead of turning off.
                        In my case this happens whenever SD card is plugged in. I've removed it and everything works as intended now
                        • X
                          Xeon @Thrasher
                          @thrasher
                          latest Firmware fixes this.
                          http://forum.m5stack.com/topic/1403/m5stickv-firmware_1017-upgrade
