M5StickC usb driver and Catalina
@m5stack could you please advise on the best process for getting M5StickC to work and flash via esptool on Mac OS Catalina ?
Also, advise on which driver is needed for M5StickC. Is it the FTDI driver or is it the CP210X driver ?
@tcruse first , on some Mac PC, M5StickC cannot upload program properly.
the solution: When programming, short the G0 to GND using the DuPont line.
and , all most PC don't need driver with M5StickC. But some old PC System need install FTDI driver.
FTDI driver is for M5StickC, CP2104 driver is for M5Stack Core ( like Fire BASIC M5GO)
@m5stack Yes, I swapped the drivers. You can check it at Apple menu, systemreport and USB.
If I connected a M5Stack I saw:
If I connected a M5StickC I saw:
You can check the loaded drivers and their versions in terminal with "sudo kextstat".
I noticed that sometimes M5Stack didn't not work without "short the G0 to GND". I think that is a timing-problem at Catalina and esptool.py. It is not a problem of M5Stack- or M5StickC-Software.
I formulated an Issue at Github: Link to Issue
Supplement on January 18, 2020: You need an Espressif account to see the issue.
@m5stack Cant click that link.
@m5stack
I got this error if I click your link: "Access denied. You do not have permission to access this page."
Thank you for updating your software.
The link worked for me once a few hours ago, but now it’s not.
@o-copleston This solution is running perfectly! Thank you!
It may make your firmware lose and make it unusable, so if you are willing to take this risk, you can chat with me in private and I will give you a link to download the tool @sheepDog @world101
@m5stack Hello, are there any news about a solution for Catalina and M5StickC?
@m5stack if you can, please give us the link for a new driver to solve that problem....
@m5stack Thank you! The solution 2 (as describe in link) is fully functional.
