    M5StickC/ATOM on MacOS Catalina can't upload/ ESP32: Timed out waiting for packet header solution (Solved)
    Official Updates
    19
    44
    244.0k
    • C
      cepics
      @world101 said in M5StickC and ATOM on MacOS platform can't upload programs solustion:
      chmod +x ch552Updater_FW20200114_A2_BTV231.dms
      ==================== M5 Serial Converter Firmware Updater ====================
      FW Version: FW20200114_A2
      This is only for update M5StickC or M5Atom Series USB Controller's Firmware
      , using it for any other purpose may cause damage to your devices.
      When you are using this software, make sure you have a reliable connection
      to your device. Any disruption during the process will cause the device
      not functioning.
                          NO WARRANTIES
      To the extent permitted by applicable law, neither wsdot,
      nor any person, either expressly or implicitly, warrants any aspect of
      this software or program, including any output or results of this software
      or program. Unless agreed to in writing. This software and program is
      being provided "as is", without any warranty of any type or nature,
      either express or implied, including, but not limited to, the implied
      warranties of merchantability and fitness for a particular purpose,
      and any warranty that this software or program is free from defects.
      Press enter to continue . . .
      Detecting M5Stack products.
      Find M5Stack products.
      Kernel driver deteched.
      Apply magic success.
      Fail to cast magic stage 2, please contact vendor.
      Waiting for device in DFU mode.....................logout
      Saving session...
      ...copying shared history...
      ...saving history...truncating history files...
      ...completed.
      Deleting expired sessions...153 completed.
      [Process completed]
      not working to me M5Atom LITE on osx 10.12.5
      • C
        cepics
        where is the G0 on M5Atom LITE??
        • m5stackM
          m5stack @cepics
          @cepics Why do you want to upgrade ... 10.12 can support the ATOM. This upgrade tool is for those systems that don't recognize the port such as MacOS Catalina
          • C
            cepics
            I have problems to upload code on M5StickC and M5Atom LITE.....
            no serial port available in tools/port menu..
            I have also burn with easyloader (on a win machine) to reset the modules
            osx 10.12.5
            arduino IDE 1.8.9
            • m5stackM
              m5stack @cepics
              @cepics you could try setup the baud to 115200. then try again. or contact our store. we will help you solve it. as soon as possible
              • H
                HerrLehmann @m5stack
                @m5stack
                I'm on macos 10.15.3 and I'm asking myself too, where is G0 on the M5Atom Matrix? Although I was able to apply the described firmware, I'm not able to connect via UIFlow IDE nor Arduino IDE (1.8.9).
                By the way: almost no image gets displayed on Safari from the documentation — neither iPad nor mac.
                • m5stackM
                  m5stack @HerrLehmann
                  @herrlehmann M5Atom Matrix have not provided G0 Pin to outside. so the solustion 1 is for m5stickC. and could you use windows os test it again? maybe is the driver software problem .
                  • C
                    cepics @m5stack
                    @m5stack said in M5StickC and ATOM on MacOS Catalina can't upload programs solustion:
                    no way!!! Atom serial port doesn't appear in the serial port list..... more than one cable tested....
                    • H
                      @m5stack
                      No, the is (un)fortunately no Windows machine. I'm a little confused about the fact, that the above mentioned firmware is running without any problem. So there needs to be a connection between mac to m5atom in some way — or how is it writing to the device?
                      • R
                        RschDev
                        My new m5stick-C are showing up on the MacOS (10.15.3) as M5 Serial Converter, and in the Arduino IDE (latest edition). I have applied the updater as suggested in this thread, and still get this response when trying to upload from the IDE to the device: "fork/exec /Applications/Arduino 2.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags: bad CPU type in executable
                        Error compiling for board M5Stick-C."
                        • m5stackM
                          m5stack @RschDev
                          @rschdev clearly. this is a compiling error . you should check the error information , and check you program.
                          • m5stackM
                            @herrlehmann did you installed the FTDI driver? you could try delete both below files. then connect your device try again.
                            /Library/Extensions/FTDIUSBSerialDriver.kext
                            /Library/Extensions/FTDIKext.kext
                            H 2 Replies Last reply Reply Quote 0
                            • H
                              I had access to a Windows machine and was able to use the easy loader on my M5Atom Matrix. It is working on Windows.
                              For my mac:
                              Yes, I installed the FTDI driver, but they did not work. I've removed them as suggested, but it didn't change anything. There is still no device appearing in /dev/, so it is not accessible.
                              • H
                                @m5stack did you dig any deeper into this? I'm still unable to use the M5Atom Matrix on my mac with Catalina. I started over again by installing and deinstalling stuff, but no new device appears. The system recognizes the M5Atom Matrix by naming a M5 Serial Converter with following information:
                                Produkt-ID: 0x6001
                                Hersteller-ID: 0x0403 (Future Technology Devices International Limited)
                                Version: 4.00
                                Seriennummer: 79525701B4
                                Geschwindigkeit: Bis zu 12 MBit/s
                                Hersteller: M5STACK Inc.
                                Standort-ID: 0x14500000 / 6
                                Verfügbare Stromstärke (mA): 500
                                Erforderliche Stromstärke (mA): 100
                                Zusätzlicher Betriebsstrom (mA): 0
                                I also applied the firmware update many times successfully.
                                @m5stack : Any other ideas? I'd like to play with it.
                                • m5stackM
                                  @herrlehmann did you have try to install the FTDI driver : https://www.ftdichip.com/Drivers/VCP.htm
                                  • P
                                    Pumpui @nsfilho
                                    @nsfilho don't update to 10.15.04....
                                    • H
                                      @m5stack : Yes, I did. By further investigating the driver, it looks like they are not working due to signing issues. I found this thread https://www.ftdicommunity.com/index.php?topic=409.msg1171#msg1171
                                      I'm waiting on this rerelease, than I'll let you know. Thanks.
                                      • C
                                        climbingrose
                                        I'm trying to apply firmware update on Catalina and having this error message:
                                        Wating for device in DFU mode..................................
                                        Any idea?
                                        R F 2 Replies Last reply Reply Quote 2
                                        • R
                                          Re4DeR @climbingrose
                                          @climbingrose I have same problem. Have you found any solution?
                                          • F
                                            Finnsen @climbingrose
                                            @climbingrose I have that same problem as well. It would be nice if @m5stack could support their products in a better manner and give us a good receipt to fix the issues.
