    Unable to burn to Atom
    Atom
    6.1k
    • V
      Vrtisworks
      I just got an Atom-Matrix. Downloaded the current burn software.
      Windows 10 computer. When I plug in the Atom, Windows sees it, and sets up a COM port (COM4).
      But I cannot seem to get the ATOM into download or setup mode.
      If I hold the button down while plugging it in, the display is blue.
      If I do NOT hold the button down while plugging it in, the display is green.
      But no matter how long I hold it down, it never turns yellow.
      Nor does it show up as an access point.
      When I try the burn program, I get this in the console log:
      Start Burn
      --chip esp32 --port COM4 --baud 921600 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x3ff000 C:\Users\Nicholas\Downloads\M5Burner\packages\fw\other\wifi.bin 0x1000 C:\Users\Nicholas\Downloads\M5Burner\packages\fw\atom\UIFlow-v1.6.5-matrix.bin
      esptool.py v2.5.0
      Serial port COM4
      Connecting...
      Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash
      MAC: 50:02:91:8e:d7:c4
      Uploading stub...
      Running stub...
      Stub running...
      Changing baud rate to 921600
      Changed.
      Configuring flash size...
      A fatal error occurred: Timed out waiting for packet header
      Burn Failed
      • V
        Vrtisworks
        I figured it out. There are two sets of instructions on flashing. One says to set the baud to 921600 and hold down the center button while powering on.
        The other says to set the baud to 750000 and Erase before you Burn. I followed those instructions, and it worked fine.
