    M5StickC ToF Hat UIFlow example missing?
    12 Posts 3 Posters 13.4k Views
      mb
      Thanks for the hint. I forgot to add the ToF Hat in UIFlow with the Hat '+' below the M5StickC.
      alt text
      Now with the simplest program (Setup+Loop), I get an error message when ToF Hat is added:
        File "flow/m5cloud.py", line 76, in _exec_fun
        File "<string>", line 8, in <module>
        File "hat.py", line 49, in get
        File "<string>", line 1, in <module>
        File "hats/_tof.py", line 9, in __init__
      AttributeError: 'module' object has no attribute 'init'
      When I remove the ToF Hat it runs again.
      Do I need to install anything? Using UIFlow v1.6.5 (web and firmware)
        ajb2k3 @mb
        @mb You haven't added any functions to the loop and so it cant initialise the TOF hat.
        Once you add a function block and the get distance block like in the example then the micropython init code will be added.
          mb
          The pure "Setup-Loop" block is running fine - as long as I do not add the ToF Hat.
          Now I have a loop block with functions inside, which works fine.
          alt text
          When adding the ToF Hat (just in the configuration) it breaks, I see a Traceback.
          alt text
          Even with ToF Hat and ToF function it does not work.
          alt text
            File "<string>", line 9, in <module>
          I am using UIFlow v1.6.5 (web and firmware).
          Has anyone the M5StickC with ToF Hat up and running? And can share the code?
            ajb2k3 @mb
            @mb well that is strange
              mb
              Maybe @m5stack can have a look. Is this a bug with v1.6.5?
              • m5stackM Online
                m5stack @mb
                @mb this is a bug. we will fix it in the next version
                  mb @m5stack
                  Thanks @m5stack. Will this be hours, days, weeks or months?
                  Just so I know when I can move my project forward.
                  • m5stackM Online
                    m5stack @mb
                    @mb already fixed. you could use the new firmware version M5StickC UIFlow 1.6.5.1
                      mb
                      Awesome @m5stack, thank you!
                        mb
                        M5StickC and ToF Hat work great with firmware UIFlow 1.6.5.1 :)
                        alt text
