    M5stickC Touch Sensing
    4 Posts 3 Posters 8.0k Views 1 Watching
    • X Offline
      xis
      I need to read the values from a touch sensing pin.
      GPIO33 is touch8 so with arduino code one can use touchread(8)
      How can I do this using UIFlow?
      Thank you.
        Hi @xls
        try something like this in an Advanced - Execute - Execute code: block:
        from machine import Pin, TouchPad
        t8 = 0
        touch8 = TouchPad(Pin(33))
        t8 = touch8.read()
        Cheers
        • world101W Offline
          world101
          Using @felmue's example, here is how I did it. For some reason I could only use the pins on the Grove port (32 or 33) of the M5StickC for capacitive touch. The GPIO pins at the top header (0, 23, 36) didn't work for me. I understand why 23 and 36 don't work (they are not one of the capacitive touch pins on the ESP32), but pin 0 should have worked according to the MicroPython docs.
          http://docs.micropython.org/en/v1.11/esp32/quickref.html#capacitive-touch
          • X Offline
            xis
            Thank you!
