    MQTT connection of CORE2 with UIFlow.
    uiflow
    7 Posts 3 Posters 11.6k Views 1 Watching
    • I Offline
      ikabou
      I've installed UIFLOW (CORE2) V1.6.5.1.
      When I make an MQTT connection with Blockly programming, it is
      overwritten on the "Wi-Fi Connect Core2" screen.
      Is there a way to avoid it?
      The publish will be correct.
      Thank you.
      • world101W Offline
        world101
        I think your issue is similar to this one...
        https://community.m5stack.com/topic/2435/wifi-connect-layer-still-shown
        I have the same issue as well. I didn’t realize this was related to MQTT, which I use in my Core2 program.
        @m5stack, please note this bug and see if you can fix it.
        By the way, for me it only happens when I download the program to the Core2. When pressing the Run button in uiFlow, I do not see the graphics issue.
        I 2 Replies Last reply Reply Quote 0
        • I Offline
          ikabou @world101
          • I Offline
            ikabou @world101
            @world101
            Yes. Only when downloaded.
            Occurs with "screen" followed by "m5mqtt" in Python's auto-generation.
            --- Blockly ---
            screen = M5Screen ()
            screen.clean_screen ()
            screen.set_screen_bg_color (0xFFFFFF)
            m5mqtt = M5mqtt ('','*. *. *. *', 1883,'','', 300)
            Rewritten with Python I overwrote the "Wi-Fi Connect Core 2" screen and erased it.
            --- Python ---
            However, it is strange that the "Wi-Fi Connect Core2" screen is displayed with "m5mqtt".
            • ZontexZ Offline
              Zontex
              Hi Guys, I noted this bug and will look into it. Will try to re-produce it and see what's going on
              • I Offline
                ikabou @Zontex
                @zontex
                I am grateful for your prompt handling.
                • ZontexZ Offline
                  Zontex @ikabou
                  @ikabou Bug confirmed and reported, we will release a fix in the next update.
