    UIFlow 1.6.6
    16 Posts 10 Posters 32.0k Views 1 Watching
      Hi guys
      yes, UIFlow 1.6.6 firmware and M5Core2 is broken for me too. M5Core2 is connected to the UIFlow server - I can turn off and on the LED. But the display stays dark. I tried to set the LCD voltage and / or brightness level but that did not help. I assume the display is not properly initialised.
      BTW: UIFlow 1.6.6 firmware for M5StickC works fine.
      Update: fully powering down (long press power button or briefly removing the battery) restored my M5Core2 with UIFlow 1.6.6 firmware.
      • m5stackM Offline
        m5stack @jesuslg123
        @jesuslg123 for the time being only for Fire & Core2
        W J 2 Replies Last reply Reply Quote 0
        • IAMLIUBOI Offline
          IAMLIUBO @OyczE
          @mati It's our server bug, fixed! Thanks for feedback.
          • IAMLIUBOI Offline
            IAMLIUBO @lelehel
            @lelehel Hi, I test it, didn't see the problem like you say.Maybe you should remove the core2 firmware and download it again?If still have this problem just tell me!
            • IAMLIUBOI Offline
              IAMLIUBO @felmue
              @felmue Good heard that!If you have any problem,just tell us!We will solve it at work day ASAP!
              • W Offline
                Wolli01 @m5stack
                @m5stack said in UIFlow 1.6.6:
                could you shared a simple sample please?
                  jesuslg123 @m5stack
                  @m5stack Thanks. Is there any plan for M5StickC?
                    Dario @jesuslg123
                    @jesuslg123 I'm using the version 1.6.6 with both StickC and SticC Plus without any issue
                      jesuslg123 @Dario
                      @dario said in UIFlow 1.6.6:
                      Are you using Bluetooth on StickC with 1.6.6? They mentioned Bluetooth is still not supported
                        Dario @jesuslg123
                        @jesuslg123 Sorry I misunderstood tha you were refering at the bluetooth on StickC and not at the at the firmware version. My bad.
                        No, I can't find the ubluetooth module on StickC
                          dsrc12 @m5stack
                          @m5stack I had problems downloading firmware updates for cores and drivers for the Arduino IDE over the last 5 days but today it all went well. All downloads worked and my test code on Fire also worked. I was able to download the latest version for Core Ink: 1.6.6.1 and it was able to connect and accept firmware from my Windows PC UIFlow IDE on-line (V1.6.6) but it would not execute any simple programs on Core Ink. It had problems with Core 2 and ended up abandoned it and completed my latest projects with Fire - it is a good stable platform and works with the latest firmware (1.6.6).
                          • ZontexZ Offline
                            Zontex @dsrc12
                            @dsrc12 said in UIFlow 1.6.6:
                            Have you tried repeating the process with UIFlow 1.4.5? is the issue only happens on 1.6.6 or also on 1.4.5? I will look into it to see what's going on.
