    CoreInk deepsleep
    7 Posts 2 Posters 12.0k Views 1 Watching
      ckuehnel
      How to deepsleep a CoreInk. The shutdown() gives a compiler error. Any idea?
      • felmueF Online
        Hello @ckuehnel
        I am running this example from master branch successfully on my CoreInk. Care to share your code?
          ckuehnel @felmue
          @felmue I tried the same w/o success. I will go into Github to look for.
            ckuehnel
            After looking into Github I must see that the installed library differed from the library at Github now.
            After updating the compilation worked and I can test the internal battery voltage over time.
            • felmueF Online
              Hello @ckuehnel
              great, I am glad you've figured it out. I am looking forward to hearing what you find regarding internal battery voltage over time.
              Cheers
                ckuehnel @felmue
                @felmue It seems to me that I measure not the battery voltage. The voltage is always around 4.8 V and this could be the voltage after the SY7088. So I can use that voltage as an indicator for enough battery voltage only. If I have schematics then I have the chance to a little bit deeper. Until now I did not find the schematics, yet.
                Ciao Claus
                • felmueF Online
                  Hello @ckuehnel
                  Without opening M5CoreInk you probably cannot measure battery voltage with a multimeter. However you can use GPIO35 to read the battery voltage. Check out float getBatVoltage() here.
                  BTW: I've opened my M5CoreInk today and added some photos to my page (link below). Measuring power consumption in light sleep, deep sleep and shutdown will be next.
                  Cheers
