M5Core2 and Lan PoE
I discover the world of the M5. In my tests, I try to connect a Lan Poe module with my new M5Core2. The M5Core2 does not start, or rather it starts and stops immediately and this in a loop. Is this module compatible with the M5Core2? If so, how do I make them work together ?
Hello @JNVoirol
most modules originally have been designed for M5Stack and before M5Core2 was available. And between M5Stack and M5Core2 a few pins on the bus have changed. I've put together a comparison sheet which might help.
That said this example should give you a starting point.
You will need to modify at least the following lines to make it work with M5Core2:
//#include <M5Stack.h> #include <M5Core2.h> ... //#define MISO 19 #define MISO 38 ... // M5.Power.begin();
Happy Stacking!
Thank you Felix.
