    M5Core2 and Lan PoE
    Core 2
    5.2k
    • J
      JNVoirol
      I discover the world of the M5. In my tests, I try to connect a Lan Poe module with my new M5Core2. The M5Core2 does not start, or rather it starts and stops immediately and this in a loop. Is this module compatible with the M5Core2? If so, how do I make them work together ?
        Hello @JNVoirol
        most modules originally have been designed for M5Stack and before M5Core2 was available. And between M5Stack and M5Core2 a few pins on the bus have changed. I've put together a comparison sheet which might help.
        That said this example should give you a starting point.
        You will need to modify at least the following lines to make it work with M5Core2:
        //#include <M5Stack.h>
        #include <M5Core2.h>
        //#define MISO 19
        #define MISO 38
        //  M5.Power.begin();
        Happy Stacking!
        • J
          JNVoirol
          Thank you Felix.
