    "Error 22 bat val error"
    7 Posts 5 Posters 10.0k Views 2 Watching
    • B Offline
      bigjohn2345
      Hello. I have received a new M5StickC, and receive the error "Error 22: Bat Val Error, Check Hardware" when plugged into USB. The screen goes dark and the device powers off when unplugged from USB. I have tried leaving it to charging for hours as well as trying to BAT to GND trick, but to no avail. How should I proceed?
      • felmueF Online
        Hi @bigjohn2345
        this error message seems to be part of the factory test. I am afraid the battery in your M5StackC got depleted so much that the voltage reading is below 3 volts and therefore the battery is considered 'dead'.
        I suggest you contact the shop and ask for a replacement.
        From FactoryTest.ino
            float VBat = M5.Axp.GetBatVoltage();
            if ((VBat < 3.0) || (VBat > 4.4))
                ErrorMeg(0x22, "Bat Vol error ");
                return false;
        • B Offline
          bigjohn2345
          Thank you; I'll do that.
          • m5stackM Online
            Charge for a while. If this message is still prompted. Just contact our store.
              Tyler_77
              Hi @m5stack
              I'm a seller in Thailand and now I have M5StickC about 10 Pcs.
              And all have the same problem is battery can't be charged and display error message "Error 22"
              After I've charged for all-day it still showing an error message.
              Or is it possible to use it while connecting the USB cable ? (don't mind about the battery)
              Thank You in Advance.
              • ZontexZ Offline
                Zontex @Tyler_77
                @tyler_77 Hello, please contact me at roni@m5stack.com and I'll do my best to assist you.
                  Tyler_77 @Zontex
                  @zontex Thank You So Much.
