    Send AT Command va UIFlow
    16 Posts 6 Posters 31.9k Views 3 Watching
    • sodokuS Offline
      sodoku
      @TheAlphaGhost which device are you using? At least one of those pins 23 and 19 that you are using is connected to an internal for most of the devices.
      • felmueF Online
        Hello @TheAlphaGhost
        from your post it is not clear which device you are using? M5Stack (Fire, Gray, Basic), M5Core2, M5StickC (Plus), M5Atom, M5CoreInk, M5Paper? They all already use some GPIOs internally so there is a chance your choice (TX 23 / RX 19) creates some overlaps.
        For instance on M5Stack and M5Core2 GPIO23 is used for SPI MOSI already or M5StickC Plus has GPIO23 already in use for LCD_DC. So the reason 'BB' stays on your screen most likely is due to GPIO23 being repurposed for UART and by doing so cutting off the LCD.
          TheAlphaGhost
          i have a M5Core device.
          Yes, i switch from TX23 -> to TX17, and RX19 -> to 16. Thanks for this tip.
          But, now i have a last question, see screenshot below.
          I Arduino i write with Serial2.write(...) the Hex. How can i do this in the UIFLOW ?!
          Please see screenshots...
          Hope you can help me, with my last question...
          • felmueF Online
            the block you are using actually writes a string "0xFA" but you want the raw hex value.
            I see two options:
            • convert the hex values into decimal values, then use a UART - write raw data block or
            • try an Advanced - Execute code block with: uart1.write(b'\xFA')
            Note: untested as I don't have the required hardware.
            Good luck!
              TheAlphaGhost
              Hi Felix,
              Vielen dank für Deine Unterstützung ! Sprichst du deutsch ?
              Thanks for your help. I will try both options, and will send a feedback here.
                TheAlphaGhost
                Mhh, still not work. Don't know what's wrong...
                • felmueF Online
                  I think the problem is now with uart1.write(ServoID). Eg. sending values from a variable. When I try this, the receiving end gets a string instead of the hex value.
                  Unfortunately I am not a Python expert - I tried a few things but nothing seems to work. Sorry about that.
                    TheAlphaGhost
                    Hi Felix,
                    no problem. Will try to find the error...
                    Thanks for your help!!
                      TheAlphaGhost
                      Hallo Felix,
                      now it's work, with byte array...
                      • felmueF Online
                        nice, congratulations and thanks for sharing. Thanks to you I've learned something new today.
                        Happy Stacking!
                        • world101W Offline
                          world101
                          I wish the blocks were in English so I don’t have to Google Translate it all 🤣🤣🤣.
                          Kidding though. I can tell by the block colors what’s going on. Nice job fixing it!
                            TheAlphaGhost @world101
                            @world101
                            Uhh, sorry. Here the english version...
