    Check your uPython version
    PROJECTS
    5
    8.3k
    • E
      ehm.education
      from m5stack import *
      from m5ui import *
      from uiflow import *
      import time
      import uos
      setScreenColor(0x000000)
      vstart = None
      vsysinfo = None
      vsecs = None
      vmins = None
      vtimetext = None
      battery = M5TextBox(0, 0, "loading", lcd.FONT_DejaVu18, 0xFFFFFF, rotate=0)
      uptime = M5TextBox(0, 32, "loading", lcd.FONT_DejaVu18, 0xFFFFFF, rotate=0)
      lb_sysinfo = M5TextBox(0, 64, "loading", lcd.FONT_DejaVu18, 0xFFFFFF, rotate=0)
      import math
      lcd.setBrightness(10)
      vstart = time.ticks_ms()
      vsysinfo = uos.uname()
      lb_sysinfo.setText(str(vsysinfo))
      while True:
        battery.setText(str((str(((str('Battery: ') + str((power.getBatteryLevel()))))) + str('%'))))
        vsecs = round(((time.ticks_ms()) - vstart) / 1000)
        vmins = math.floor(vsecs / 60)
        vtimetext = (str((vsecs % 60)) + str('s'))
        if vmins != 0:
          vtimetext = (str(((str(vmins) + str('m ')))) + str(vtimetext))
        vtimetext = (str('Uptime: ') + str(vtimetext))
        uptime.setText(str(vtimetext))
        wait_ms(2)
        mb
        Interesting, when executing on a M5Stack Core2 via REPL I get an error message:
          File "<stdin>", line 21, in <module>
        AttributeError: 'TFT' object has no attribute 'setBrightness'
        • world101W
          world101 @mb
          @mb
          Different code...
          Core:
          Core2:
          screen.set_screen_brightness(10)
            mb
            I would prefer to have a stable API for all devices. Current situation makes re-use of code complicated.
            Someone could write a wrapper API to cover the differences ;-)
            alt text
            xkcd comic
              I'm trying to push for a unified API but the problem is that some of the devices are slightly different and require slightly different commands.
              Please add your request for a unified API to the suggestions list.
