    How to erase M5Stick-C completely?
    M5 Stick/StickC
    5.0k
    • H
      HaSch
      I have a M5Stick-C and played around with it a while. I flashed it with UI Flow 1.7.2 and tried to flash with 1.4.5 after that. It doesn't work I get the message that it doesn't have enough memory. Even the Sketch "Factory Test" isn't flashable using Arduino IDE: Not enough memory! I tried to erase the chip with M5Burner 2.2.4 and got the following message:
      Erase now
      esptool.py v2.5.0
      Serial port /dev/tty.usbserial-FD51B432F3
      Connecting....
      Detecting chip type... ESP32
      Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse
      MAC: 24:a1:60:54:44:dc
      Uploading stub...
      Running stub...
      Stub running...
      Erasing flash (this may take a while)...
      Chip erase completed successfully in 2.0s
      Hard resetting via RTS pin...
      Erase Successfully
      It seems to be ok but the result is as before. How can I erase the chip COMPLETELY?
