Issue with esp32 board lib v1.0.5
I would like to report an issue with M5Stack Core GRAY/BASIC.
If you have installed esp32 board lib v1.0.5 and run code like above, you will find that the statement Serial.begin() has a conflict with the statement M5.begin(). You will never get into the loop.
With esp32 1.0.4 and lower it is ok.
The strange thing is that when i remove Serial.begin() it works and still prints with 115200 baud.
I do not know wether the issue is in the lib esp32 or m5stack.
Regards PatrickHere is an example:
#include <M5Stack.h>int i = 0;
void setup(void) {
Serial.begin(115200); // comment this line if esp32 lib 1.0.5 is installed!M5.begin();
M5.Power.begin();
M5.Lcd.setCursor(10, 20, 4);
M5.Lcd.setTextColor(TFT_YELLOW);
M5.Lcd.setTextSize(1);
M5.Lcd.print("Hello World!");
delay(2000);
M5.Lcd.clear(TFT_BLACK);
}void loop() {
M5.Lcd.fillRect(10, 20, 100, 19, TFT_BLACK);
M5.Lcd.println(i);Serial.println(i);
i++;
delay(1000);
Hello @Pat
if you look into
M5.begin()
you'll see that there already is aSerial.begin()
call.if (SerialEnable == true) { Serial.begin(115200); Serial.flush(); delay(50); Serial.print("M5Stack initializing..."); }
In my experience calling
Serial.begin()
twice is a bad idea and can lead to very strange errors.
Thank you Felix for the quick answer. I confess did not looked in the M5 source. So its more a feature than a bug.
My problem was, that i am communicating with other hardware where i can not easily change the baudrate to 115200. Must touch the M5Stack lib for that.
A property for baudrate value would be nice.
Still do not understand why the problem was only since the esp32 release to 1.0.5 and not earlier.
Regards Patrick
Hello @Pat
you are welcome.
BTW: you do not necessarily need to touch the M5Stack lib -
M5.begin()
actually has parameters, one of them isSerialEnable
, if you set this tofalse
you can setupSerial
in your code anyway you like.Thanks
