    uiFlow v1.7.3 Double Setup block error
    3 Posts 2 Posters 4.2k Views 1 Watching
    • L Offline
      L24ever3
      Sometimes another setup block appears. And when I run my code the core 2 freezes.
      • world101W Offline
        world101 @L24ever3
        @l24ever3
        Does the duplicate remain if you save the file, refresh the webpage, and load the program again?
        I've had a missing Setup block before, but not a double Setup block. I fixed the missing one by modifying the m5f file in a text editor to add the necessary code back to the file. I used a blank file with just the Setup block as reference. Perhaps you can do something similar to find the duplicate code?
        If you can't figure it out, post a link to the file and I'll have a look to see if I can fix it.
        • L Offline
          L24ever3
          Yes, the duplicate remain if i save the file, refresh the webpage, or load the program again! But in the meantime I figured out the solution. Just right click to block and disable.
