    How to test if the M5Paper is attached to USB power?
    PRODUCTS
    4.1k
    • D
      dov
      I'd like to have different behavior whether the M5paper is running of USB power or battery. I guess I can just try to go to sleep and if it "fails" and I reached the next statement, the I'm on USB power (since you never deep sleep when connected). But is there a more direct way?
      • D
        dov
        Answering my own question. This was trivially simple in my code. My code was doing deep sleep in the setup() function. When waking up from deep-sleep the setup function is called again. But if the device is powered by USB then deep sleep fails and we will reach the loop() function. So any special code that I want for USB power should simply be put in loop().
