Unit V2 Wi-Fi AP
  • Hi Everyone,
    I just got the Unit V2.
    I did not see a new AP when connecting it to a USB power supply so I connected it to my Laptop running MacOS and a new network adapter showed up.
    I was able to ssh to the device by using the default credentials. However, I was not able to login as root or using sudo. This is the error I get when trying sudo:
    unitv2% sudo sh
    sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
    unitv2% ls -la /usr/bin/sudo
    -rwxr-xr-x 1 avahi avahi 83152 Apr 5 2021 /usr/bin/sudo
  • There are more problems without "root" :(
    unitv2% date -u 060511102021
    date: can't set date: Operation not permitted
    Sat Jun 5 11:10:00 UTC 2021
    unitv2% date
    Thu Jan 1 00:18:32 UTC 1970
  • I'd solv it.
    You can change the device to notebook mode. There have terminal in notebook. The terminal in notebook can run command su by no password. Have a pleasure.
  • I already access it by the terminal in notebook. The terminal in notebook can process su to modify it.
  • @justin Thank you, I will give this a try.
  • Hello,
    Thanks for the valuable information in this forum. I received my UnitV2 yesterday and was quite disappointed, but after reading your comments I feel that I'm not the only one:
    • no AP (although promised)
    • the USB-Network works fine under Linux (no extra driver required) and Windows (with proposed driver)
    • the installation of the new firmware 20210604 was OK - but it destroyed 01-Introduction to M5Stack UnitV2.ipynb
    • as m5stack-user I can't even delete a file in the /home/xxxx directories. sudo fails too.
    • root user works fine but who wants to work as root?
    • tests with jupyter notebook were sometimes successful but most session ended with a kernel crash. I was able to save an image as jpg but matplotlib didn't work.
    So, conclusio for now: let's wait for the next update of the firmware.
    Kind regards
    Bernd
  • This post is deleted!
  • @bkircher I dunno if this is useful but i just came across this0_1624225217714_wifimode.png
  • Here is the js file for the wifi button to connect....
  • @m5stack Can you also reset the network configuration files in the firmware for next release?
    Reset these files if modified
    dhcpcd.conf
    dnsmasq.conf
    hostapd.conf
    in /etc/
  • @asmodev thank you feedback , we will check it.
