    UIFlow 1.7.6
    20 Posts 9 Posters 34.9k Views 2 Watching
      Hello @ajb2k3
      I don't know for sure for which core the GoPlus2 was designed for, but I think it was meant for M5Stack (Gray, Fire, etc.).
      All I can say (looking at the schematic) is that electrically it is not fully compatible with the M5Core2.
      Also, all Arduino examples I can find are for M5Stack (Gray, Fire, etc.) and none for M5Core2.
      And the GoPlus (first generation) is EOL.
      BTW: I don't think the '2' is because it is meant for M5Core2. It's simply the successor of the first GoPlus module. Which, if I am correct, is an unlucky (and confusing) naming.
        ajb2k3 @felmue
        @felmue I took it that it was for the core 2 as it has the different case shape and the longer Mbus header pins
        • m5stackM Online
          m5stack @Doswiadczalnik
          @doswiadczalnik now it fixed. you could remove the old firmware file then download again.
            8Servos hat intermittent response with 1.7.6
            • OyczEO Offline
              OyczE
              @m5stack when we gonna see UiFlow with zigbee Init and COM ?
              • m5stackM Online
                m5stack @ajb2k3
                @ajb2k3 could you share your code here? it would helpful for us to debug it.
                • m5stackM Online
                  m5stack @OyczE
                  @mati It is in our support plan and will be supported in future updates. so maybe after a few weeks, it will be supported.
                  • OyczEO Offline
                    OyczE @m5stack
                    @m5stack thx, maybe some day uiflow will be able to support new HW at rls day ;)
                      plusulli
                      I cannot get a QRCODE for the Cloud with the UNITCAM examples.
                        kmart93179
                        I use weight unit for port A and the GOPlus2 Base at the same time. it seem like it cant work together,When i trigger the server motor ,my weight unit dont work anymore,the label keep show 0 ,i think maybe is I2C issue ,any ideas?
                        thx
                        skyler
                          kmart93179
                          • m5stackM Online
                            m5stack @kmart93179
                            @kmart93179 weight unit is not used the I2C protocol of course they not compatible.
