    M5Paper on macos Big Sur
    25 Posts 5 Posters 62.7k Views 3 Watching
    • N Offline
      nigel
      I am unable to connect to my m5paper on Big Sur.
      I've installed CP210x_VCP_MacOS.zip
      When the device is connected I can see a new device: /dev/tty.usbmodem52D40004421
      However I cannot connect to it with m5burner or uiflow desktop IDE.
      I have disable checking third party software and allowed software from "any".
      I have tried multiple cables.
      USB C to USB C cable
      USB C to USB A (with an adapter) cable.
      Any other suggestions ?
      • m5stackM Online
        can't connect it to the M5Burner? why? when uploading the firmware it has some abnormal situation? could you say more detail. also. if you wanna connect to the Desktop IDE you need setup the device to the USB mode. we suggest you use the online version.
        • N Offline
          nigel
          I would love to use the online version, but I understand that I need the API key.
          To get the API key I have to update the firmware, right ? I don't see any other way to get the API key.
          (I have the m5paper 1.1)
          When I start m5burner and select the device port "/dev/tty.usbmodem52D40004421" nothing happens. No error message. No options to apply another firmware.
          When I try the same device in the desktop IDE, it says failed to connect, check that the device is turned on.
          How do I set it to USB mode?
          (I will upload some screenshots in a couple of hours)
            Have you restarted the Mac? USBmodem is the wifiadapter on the Mac
            It looks like the driver has been updated and is playing silly again.
            • N Offline
              nigel
              That does not seem to be the case
              Before connecting the M5paper
              ❯ ls -l /dev/tty.*
              crw-rw-rw- 1 root wheel 20, 0 23 Sep 20:16 /dev/tty.Bluetooth-Incoming-Port
              crw-rw-rw- 1 root wheel 20, 2 23 Sep 20:16 /dev/tty.WI-C200-serialport
              After connecting the m5
              ❯ ls -l /dev/tty.*
              crw-rw-rw- 1 root wheel 20, 4 24 Sep 19:24 /dev/tty.usbmodem52D40004421
              • N Offline
                nigel @nigel
                To answer you other question, yes, I have restarted the laptop.
                I did a power off, then power on with the physical button. (not just a reboot)
                • N Offline
                  nigel @nigel
                  This is the screenshot of the error from the IDE
                    ajb2k3 @nigel
                    @nigel this message is a nightmare as it often means that there is a server issue but it could mean other things
                      Are you using safari because safari on OSX is seriously broken at the moment.
                      • N Offline
                        nigel @ajb2k3
                        That's the desktop application installed locally.
                        I can't use the web UI Flow. I need to update the firmware to get the API key.
                        I can't update, because I can't connect with m5burner.
                        • m5stackM Online
                          https://docs.m5stack.com/en/quick_start/m5core/m5stack_core_get_started_uiflow
                          make the software install is correct.
                          • N Offline
                            nigel @m5stack
                            @m5stack
                            I have followed the instructions. As I can see the driver is installed :
                            ❯ ls -ld /Library/Extensions/Si*
                            drwxr-xr-x 3 root wheel 96 3 Nov 2016 /Library/Extensions/SiLabsUSBDriver.kext
                            The application is in the applications folder as well :
                            Factory test on the device looks good
                            I have also tried uninstalling the driver. Reinstalling and rebooting.
                            • N Offline
                              nigel
                              @m5stack
                              I suppose the drive isn't loading, so I tried to load it on the cli :
                              sudo kextload /Library/Extensions/SiLabsUSBDriver.kext
                              Password:
                              Executing: /usr/bin/kmutil load -p /Library/Extensions/SiLabsUSBDriver.kext
                              Error Domain=KMErrorDomain Code=71 "Unsupported Error: one or more extensions are unsupported to load Kext com.silabs.driver.CP210xVCPDriver v4.10.14 in executable kext bundle com.silabs.driver.CP210xVCPDriver at /Library/StagedExtensions/Library/Extensions/SiLabsUSBDriver.kext" UserInfo={NSLocalizedDescription=Unsupported Error: one or more extensions are unsupported to load Kext com.silabs.driver.CP210xVCPDriver v4.10.14 in executable kext bundle com.silabs.driver.CP210xVCPDriver at /Library/StagedExtensions/Library/Extensions/SiLabsUSBDriver.kext}
                              Does the driver support Big Sur 11.4
                                Ok, I have found that there is currently an issue in OSX in that the driver is randomly not being loaded for the adapters.
                                As typical Apple have broke something.
                                • N Offline
                                  nigel @ajb2k3
                                  @ajb2k3 said in M5Paper on macos Big Sur:
                                  It consistently fails to load, not randomly. At least that's the case for me.
                                  What's your source?
                                  @m5stack Can you confirm is this was tested on Big Sur 11.4 ?
                                  Unless someone can confirm they have has it working on that specific version it's more than likely the driver was not built for this OS.
                                  There are over 550 kernel extensions on my mac and they all work perfectly. It seems the interface Apple exposes for loading extensions works for everyone else.
                                  • N Offline
                                    nigel @nigel
                                    @m5stack
                                    For general information Silicon Labs has a newer version of the driver which I can load.
                                    But that does not work either :(
                                    https://www.silabs.com/developers/usb-to-uart-bridge-vcp-drivers
                                      Was working on 10.14 but 10.15 fails.
                                      • N Offline
                                        nigel @ajb2k3
                                        I'm on 11.14 Big Sur
                                        10.14 would be Mojave released in 2018
                                        @m5stack
                                        At this point I can only assume recent macos is not supported and I'll and get my hands on a windows computer :-(
                                          ajb2k3 @nigel
                                          @nigel Im on Catalina (just upgraded from Mojave) and now have the issues :(
                                            darul75
                                            hello I got the exact same issue with my mac book pro, I will add some more details, I am using the default apple mac https://www.apple.com/shop/product/MUF82AM/A/usb-c-digital-av-multiport-adapter and then the Burner app, it does display the same option ttyusbmodem something. It would be great to find a workaround to be able to updgrade the firmware and start innovating ;)
