    M5Paper on macos Big Sur
    25 Posts 5 Posters 62.7k Views 3 Watching
      Have you restarted the Mac? USBmodem is the wifiadapter on the Mac
      It looks like the driver has been updated and is playing silly again.
      • N Offline
        nigel
        That does not seem to be the case
        Before connecting the M5paper
        ❯ ls -l /dev/tty.*
        crw-rw-rw- 1 root wheel 20, 0 23 Sep 20:16 /dev/tty.Bluetooth-Incoming-Port
        crw-rw-rw- 1 root wheel 20, 2 23 Sep 20:16 /dev/tty.WI-C200-serialport
        After connecting the m5
        ❯ ls -l /dev/tty.*
        crw-rw-rw- 1 root wheel 20, 4 24 Sep 19:24 /dev/tty.usbmodem52D40004421
        • N Offline
          nigel @nigel
          To answer you other question, yes, I have restarted the laptop.
          I did a power off, then power on with the physical button. (not just a reboot)
          • N Offline
            nigel @nigel
            This is the screenshot of the error from the IDE
              ajb2k3 @nigel
              @nigel this message is a nightmare as it often means that there is a server issue but it could mean other things
                Are you using safari because safari on OSX is seriously broken at the moment.
                • N Offline
                  nigel @ajb2k3
                  That's the desktop application installed locally.
                  I can't use the web UI Flow. I need to update the firmware to get the API key.
                  I can't update, because I can't connect with m5burner.
                  • m5stackM Online
                    https://docs.m5stack.com/en/quick_start/m5core/m5stack_core_get_started_uiflow
                    make the software install is correct.
                    • N Offline
                      nigel @m5stack
                      @m5stack
                      I have followed the instructions. As I can see the driver is installed :
                      ❯ ls -ld /Library/Extensions/Si*
                      drwxr-xr-x 3 root wheel 96 3 Nov 2016 /Library/Extensions/SiLabsUSBDriver.kext
                      The application is in the applications folder as well :
                      Factory test on the device looks good
                      I have also tried uninstalling the driver. Reinstalling and rebooting.
                      Any other suggestions ?
                      • N Offline
                        nigel
                        @m5stack
                        I suppose the drive isn't loading, so I tried to load it on the cli :
                        sudo kextload /Library/Extensions/SiLabsUSBDriver.kext
                        Password:
                        Executing: /usr/bin/kmutil load -p /Library/Extensions/SiLabsUSBDriver.kext
                        Error Domain=KMErrorDomain Code=71 "Unsupported Error: one or more extensions are unsupported to load Kext com.silabs.driver.CP210xVCPDriver v4.10.14 in executable kext bundle com.silabs.driver.CP210xVCPDriver at /Library/StagedExtensions/Library/Extensions/SiLabsUSBDriver.kext" UserInfo={NSLocalizedDescription=Unsupported Error: one or more extensions are unsupported to load Kext com.silabs.driver.CP210xVCPDriver v4.10.14 in executable kext bundle com.silabs.driver.CP210xVCPDriver at /Library/StagedExtensions/Library/Extensions/SiLabsUSBDriver.kext}
                        Does the driver support Big Sur 11.4
                          Ok, I have found that there is currently an issue in OSX in that the driver is randomly not being loaded for the adapters.
                          As typical Apple have broke something.
                          • N Offline
                            nigel @ajb2k3
                            @ajb2k3 said in M5Paper on macos Big Sur:
                            It consistently fails to load, not randomly. At least that's the case for me.
                            What's your source?
                            @m5stack Can you confirm is this was tested on Big Sur 11.4 ?
                            Unless someone can confirm they have has it working on that specific version it's more than likely the driver was not built for this OS.
                            There are over 550 kernel extensions on my mac and they all work perfectly. It seems the interface Apple exposes for loading extensions works for everyone else.
                            • N Offline
                              nigel @nigel
                              @m5stack
                              For general information Silicon Labs has a newer version of the driver which I can load.
                              But that does not work either :(
                              https://www.silabs.com/developers/usb-to-uart-bridge-vcp-drivers
                                Was working on 10.14 but 10.15 fails.
                                • N Offline
                                  nigel @ajb2k3
                                  I'm on 11.14 Big Sur
                                  10.14 would be Mojave released in 2018
                                  @m5stack
                                  At this point I can only assume recent macos is not supported and I'll and get my hands on a windows computer :-(
                                    ajb2k3 @nigel
                                    @nigel Im on Catalina (just upgraded from Mojave) and now have the issues :(
                                      darul75
                                      hello I got the exact same issue with my mac book pro, I will add some more details, I am using the default apple mac https://www.apple.com/shop/product/MUF82AM/A/usb-c-digital-av-multiport-adapter and then the Burner app, it does display the same option ttyusbmodem something. It would be great to find a workaround to be able to updgrade the firmware and start innovating ;)
                                        I found an issue with the driver and had to select the kext file and now the driver works and usb serial is now working again!
                                          darul75 @ajb2k3
                                          Hi @ajb2k3 what do you mean by selecting the ktext file, something like
                                          sudo kextload SiLabsUSBDriver.kext
                                          me it does not change anything, I am on OS Catalina
                                            ajb2k3 @darul75
                                            @darul75 said in M5Paper on macos Big Sur:
                                            Select? wow autocorrect!
                                            Nope, It should read delete.
                                            OSX has another driver that is conflicting with the slabs driver.
