    M5stack cam no picture
    10 Posts 2 Posters 18.4k Views 1 Watching
      corto
      i bought a M5Stack Official ESP32 WROVER with PSRAM Camera Module OV2640 Type-C Grove Port Mini Camera Development Board Building Brick.
      It was always rebooting
      Rebooting...
      ets Jun 8 2016 00:22:57
      rst:0xc (SW_CPU_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      Rebooting...
      i load : Github.com/m5stack/esp32-cam-demo/tree/m5cam-psram
      result:
      wifi ok
      but no image just a black screen with a small white square in the center
      i load : m5cam-firmware.zip
      result:
      wifi ok
      but the red led is off
      i read on com :
      I (569) camera_demo: Camera demo ready
      I (19499) camera_demo: station:44:78:3e:5f:ec:2e join, AID=1
      dhcps: send_offer>>udp_sendto result 0
      I (20269) tcpip_adapter: softAP assign IP to station,IP is: 192.168.4.2
      W (26249) http_server: Expected response size: 18400, actual: 0
      what is wrong?
        ajb2k3 @corto
        @corto did you get a file downloading from the camera?
          corto
          Yes i have
            corto
            Yes i have
              Thats the default demo firmware. it should have created a file.
              Look at you wifi connections, do you see M5cam in the wifi manager?
              Mine doesn't show anything on the screen but does capture images.
              Also, they do overheat badly.
                corto
                Yes i see m5stack wifi 192.168.4.1 and the connexion is ok
                  http://192.168.4.1 is the address.
                  http://192.168.4.1:80 is the only open port.
                  http://192.168.4.1/pgm grayscale image.
                  http://192.168.4.1/bmp_stream - BMP stream.
                  http://192.168.4.1/jpg_stream - jpg stream.
                  But again, you may not see anything on the screen.
                    corto
                    idem no picture
                      Look in your "downloads folder" (where ever you download files to)
                      You should see a strange file. When you open the file, there will be captured images in it.
                      I'm waiting on my MK2 camera (WROVER) to arrive to see what the difference in the 2 are.
                        corto
