    Serial2 Don't compile
    9 Posts 3 Posters 21.7k Views 2 Watching
      ardisd
      I have recently changed to using https://dl.espressif.com/dl/package_esp32_index.json in the boards manager now any application using serial2 wont comple. I get an error Error compiling for board M5Stack-Core-ESP32.
      David Ardis
        ajb2k3 @ardisd
        @ardisd Can you post a screenshot of the error ouput from arduino?
          ardisd
          Enclosed screen shot as requested
          I get the same error when compiling Serial2.ino and my own code
            Are you running arduino 1.8.7?
            Thats not all the error.
              ardisd
              Upgraded to 1.8.7 was on 1.8.5
              This is the error now
                I first thought is to tell you to Backup and delete the SD folders in dropbox and
                C:\programfiles(x86)\Arduino\Librarys\SD
                and then try again.
                Can I see your source code?
                  ardisd
                  Just the standard serial2 sketch
                  #include <M5Stack.h>
                  HardwareSerial Serial2(2);
                  Serial.begin(115200);
                  // Serial2.begin(unsigned long baud, uint32_t config, int8_t rxPin, int8_t txPin, bool invert)
                  Serial2.begin(115200, SERIAL_8N1, 16, 17);
                  if(Serial.available()) {
                  int ch = Serial.read();
                  Serial2.write(ch);
                  if(Serial2.available()) {
                  int ch = Serial2.read();
                  Serial.write(ch);
                  • N Offline
                    nnn
                    I got the same problem.
                    I changed the rename of Serial2 and fixed it.
                    →HardwareSerial Serial2_(2);
                      ardisd
                      @nnn 在 Serial2 Don't compile 中说:
                      That worked for me
                      David Ardis
