    2. nnn
    N
    • Continue chat with nnn
    • Start new chat with nnn
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Save
    Saving
    nnn
    @nnn
    0
    Reputation
    1239
    Profile views
    0
    Followers
    Following
    Joined Last Online
    nnn Follow
    Posts made by nnn
    • RE: Where is LAN Module example??
      My problem was solved below.
      https://github.com/m5stack/M5Stack/tree/master/examples/Modules/W5500
      https://github.com/m5stack/m5stack-documentation/issues/4
      posted in PRODUCTS
      N
      nnn
    • RE: Serial2 Don't compile
      I got the same problem.
      I changed the rename of Serial2 and fixed it.
      HardwareSerial Serial2(2);
      →HardwareSerial Serial2_(2);
      posted in PROJECTS
      N
      nnn
      And, Arduino Example page in M5Stack LAN Module is "Page not found".
      M5Stack-Admin,I want you to correspond.
      https://github.com/m5stack/m5stack-documentation/blob/master/en/product-documents/modules/m5stack_lan_module.rst
      posted in PRODUCTS
      N
      nnn
      I found an example of W5500, but it did not work.
      W5500 example is
      https://github.com/adafruit/Ethernet2
      But,I get the following error in my environment.
      Failed to configure Ethernet using DHCP
      My code is
      #include <SPI.h>
      #include <Ethernet2.h>
      byte mac[] = {
        0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
        if (Ethernet.begin(mac) == 0) {
          Serial.println("Failed to configure Ethernet using DHCP");
          // no point in carrying on, so do nothing forevermore:
          for(;;)
        Serial.print("My IP address: ");
        for (byte thisByte = 0; thisByte < 4; thisByte++) {
          Serial.print(Ethernet.localIP()[thisByte], DEC);
          Serial.print(".");
        Serial.println();
      posted in PRODUCTS
      N
      nnn
    • Where is LAN Module example??
      I would like to try "LAN Module with W5500 Chip".
      posted in PRODUCTS
      N
      nnn
