M5Stamp C3 and Arduino IDE
I just ordered 5 pcs of new M5Stamp C3 and would like to know what ESP32 board I have to choose to program in Arduino IDE. I downloaded newest version of ESP32 boards but M5Stamp C3 isn't included.
@felmue said in M5Stamp C3 and Arduino IDE:
have look here. Check out section ESP32-S2 and ESP32-C3 Support
Thank you Felix, that was the solution. I think it is ESP32C3 Dev Module.
Best regards,
Hans -
Today, I received the boards but in Arduino IDE they seem not to work with board ESP32C3 Dev Module. -
@felmue Error message:
esptool.py v3.1
Serial port /dev/cu.usbmodem53220362951
Connecting....
Chip is unknown ESP32-C3 (revision 3)
Features: Wi-Fi
Crystal is 40MHz
MAC: xx:xx:xx:xx:xx:xx
Uploading stub...A fatal error occurred: Failed to write to target RAM (result was 01070000)
A fatal error occurred: Failed to write to target RAM (result was 01070000) -
I have this error on several devices now.
Hello @HaSch
The error message looks familiar - see this thread.
FelixI looked at this thread but it didn't work for me. Grounding Pin 9 and trying to flash ends with the same result.
How can I use another TTL2USB port? I only have the one provided using the board.
